drive shaft balancing?
Has anyone ever had the SVX drive shaft assembly balanced? I'm looking at the whole mess and wondering if its even possible. Perhaps it would have to be disassembled into its two main components and each of the two components balanced?
Do you think it needs to be balanced?
Are you getting vibrations? If so it's more likely the U-joints. If not then just ignore this post.
Any shop equiped for the task can balance a driveshaft with a carrier. In fact it needs to be together to be balanced properly.
I've had one balanced before. It had the carrier on it. It cost about $75.00 I had it done at A1 Driveshaft in Milwauukee. They are a heavy truck shop. I tend to look for truck and machinery shops for drivetrain and suspension stuff because they seem to have the guys that have been doing this stuff for 20 years and know what forces can do to a part.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip 1992 LS Touring (6/91) Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler 1994 LSi (4/93) Bordeaux Pearl; 198,000 miles; Mods: Weight reduction. 1969 Mustang GT Convertible 1970 Mustang Convertible 2000 Ford Excursion Sola lingua bona est lingua mortua. My Locker Last edited by mohrds; 03-13-2003 at 08:01 PM. |
$75 just to balance it. I got mine lengthned and balanced for $100. Guess I got a good deal.
Re: drive shaft balancing?
Bump from the dead.
Where in central village did you have that driveshaft balanced Subafreak? |
Holy 13 year bump!
Subafreak was last online in 2012, so you may be waiting to get an answer for a little while.
Yeah I sent him a pm too.
Shot in the dark I know. The first place I contacted wanted to sell me a brand new one instead. Central village is right down the road from me so wherever he went should be close by. |
