285 whp!
wow..... Just wow...
Thats wheel HP?? might wanna check on that because I highly doubt that
Tom |
Holly Hell Batman!
285 WHP NA with cams, milled heads, and flow work? Holy ****
I have to agree... that sounds like a lot!
I asked if it was whp.... Let's wait and see
Okay... This waiting thing stinks. What is it already...
I'm going to say its crank HP. He said it was up 60 hp so I imagine he meant the baseline was 230hp.
what I wouldn't do for some dyno tuning
Tom |
/me wants to see a stock vs. modified dyno graph!
Sell the new lift and get a dyno
I rode in Jack's RS last year at Watkins Glen, before he did the engine work. He already had the Autronic, and it was pretty much keeping up with a modestly upgraded Sti. It is a great car. I believe that he could easily be pulling 285 whp now. He said at that point he was pulling over 210. I think the secret is the stand-alone ECU, so he can tune it for max hp without any concern for emissions, or idle smoothness. Also, no frigging engine braking. The EG33 block and heads are a great design. Once it is freed of the mundane concerns of a street legal machine, there is no reason why it can't make prodigious HP, even NA.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
Note to self - get "worked over" heads on the flow bench...
-Bill
So what does that equate to in flywheel HP? 420 HP? NA? That seems a bit high. That is better than the S2000's HP/displacement ratio which makes that much HP by running craploads of RPMs.
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
