Old 09-04-2009, 07:45 PM
FriendlyTurkey FriendlyTurkey is offline
Rigoli's Block
I found this interesting when I was searching for more information regarding TRP's EG33. Here's a picture of their block. Stock sleeves from what I can tell. Anyone know if they continued to use this method long term on the drag car?
Old 09-04-2009, 08:14 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: Rigoli's Block
Definitely not stock -- check the wire o-rings and the pieces of aluminum rod welded in around each bore....
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-04-2009, 09:56 PM
Re: Rigoli's Block
-Bill
I notice those modifications, but the actual sleeves are stock.
FT
Old 09-05-2009, 12:51 AM
Re: Rigoli's Block
This is what we call by semi-closed deck.
Old 09-05-2009, 01:30 AM
Gamesy's Avatar
Gamesy Gamesy is offline
Re: Rigoli's Block
really? we have a semi closed deck? i thought we had a closed deck?
Old 09-05-2009, 02:03 AM
Re: Rigoli's Block
No we have an open deck. Rigoli added those bits in there.
Old 09-05-2009, 04:30 PM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
Re: Rigoli's Block
-Bill
Looks like the block was drilled and the aluminum pins were just pressed in place. I don't see signs of welding (which would anneal the heat treatment of the block anyway).
I was thinking of drilling and tapping for threaded pins for my next project EG33 block, but I wonder if these non-threaded pins were glued in place as well?
Bob Légère
EG33 Impreza tweaks
Old 09-05-2009, 04:41 PM
Re: Rigoli's Block
You cannot really tell Bob. I magnified the picture I can see there a little bit of welding on the outer block side, not the sleeve part...
Old 09-05-2009, 06:36 PM
Re: Rigoli's Block
Hmmm...If the pins were pressed in, what are the odds of one or two being just a couple thousandths off and warping a sleeve?
...Unless you bored/honed the cylinders after pressing in the pins. Duh. Me tired.
Old 09-05-2009, 10:38 PM
SVXRide's Avatar
Re: Rigoli's Block
Bob,
I agree with you. There is only one pin that looks like it might have some sort of adhesive/welding on -- far right cylinder at about the 8:00 location.
-Bill
Old 09-06-2009, 01:23 AM
Lightbulb Re: Rigoli's Block
Since Rigoli's block is out for the public, it wouldn't hurt shooting them an email asking about the pins, right? I'm gonna do it and let you know guys...
Old 09-07-2009, 06:55 PM
Re: Rigoli's Block
hey.
they are just pressed in.
Regards,
Dom Rigoli
Unit 11, 7 Birmingham Avenue
Villawood NSW, 2163
Sydney, Australia
Phone: +61 2 9727 0695
Fax: +61 2 9727 4697
www.tonyrigoliperformance.com.au
sales@tonyrigoliperformance.com.au
