Replace clutch in Forester turbo
New clutch. Do you always have. To put in a new. Flywheel . He is. Changing it. Because the. Throw out. Bearing is making. Noise . 170,000 miles on a Subaru forester. Turbo . 2005????. Do u need to use. OEM clutch and press plate. What is. A. Good. Place. To get them ?
Re: Replace clutch in Forester turbo
resurfacing the flywheel is probably the way to go and a lot cheaper. most of the clutch kits come with oe bearings. just make sure the pilot bearing is quality or you will be doing it again for noise (don't replace a needle pilot bearing with a brass one).
Is it a dual-mass flywheel? If so it will probably need to be replaced.
-Brian Current fleet: 89 D21 2wd 91 XT6 93 D21 4wd 95 SVX LSi 02 Windstar Sport 03 CL500 03 Avalanche NF 07 RDX 08 Outback 10 Outback 10 Murano 12 Accent 15 STi |
No. It isnt.
that is phone typing. Mine does it too sometimes. You just have to catch it.
Matt 15 OBW premium w/eyesight A picture of an SVX in the garage |
Oh. I. Get. It.
Actually iPad and it puts in ....... Any time it feels like. It also spell checks by it self. If u don't keep an I on it it makes new sentences.
If you push space twice, it puts a period. It's a shortcut. Don't doubletap space, and it won't do that anymore.
