Replacement spark plug boots?
I need to do my plugs and valve cover gaskets soon. So, I went looking for new spark plug boots, but to no avail. Searching indicates that Subaru doesn't sell them separately, and you have to get new coils if you want new boots. I found a few threads with people who had the same problem, but no good alternates to OEM boots were located at that time. But, these threads were a few years old - are there still no boots to be had, or has someone found something since then?
There were some mumblings about a universal plug wire set with a single boot (for the distributor wire) that works, but it sucks buying a whole wire set for $40+ just to get one boot and then throwing the rest out. I found a post where someone listed the dimensions - 1.5" length, 3/8" ID over the plug, 5/8" ID over the coil. With these dimensions in-hand, I searched all over the internet, but found nothing. Called MSD's tech line - they didn't have anything either. I fired off an email to Accel, but haven't heard back yet (and am not really expecting anything either). Does anyone know if there is anything out there that works?
Re: Replacement spark plug boots?
Ummmmmm....The SVX doesn't have a distributor. It's a coil-on-plug ignition, so there are 6 individual coils sitting right on the spark plugs. The boot is part of the coil, they are molded in together and don't come apart.
I was under the impression that the boot slipped over the end of the plug, and also over the end of the coil pack though - not molded as part of the coil. I haven't pulled mine out to look at them, but everything I've read suggests that the boot is replaceable - just not available separately.
When I replaced the plugs on my car I didn't notice if the boots are removable, although I didn't pull on them to check.
As far as I know, the boots are not replaceable. You have to get new coils to replace them.
I have a somewhat rough idle, and some driveability problems. I have reason to suspect bad plugs or a coil arcing...hopefully it's just plugs. When I got my car, the previous owner gave me 3 (yes, 3) new spark plugs with it...so I'm probably running on 3 fairly new plugs, and 3 with who knows how many miles on them. I guess I'll see when I tear into it.
