A/C Issues
I had my a/c retrofitted a while back and it doesn't work anymore, it never really did even when it was first retrofitted. I am going to try and troubleshoot it myself and fix it, but is it possible to use the FSM's regarding the a/c system with an a/c system that is retrofitted with the R134 stuff? I have a 92 svx.
If it hasn't really worked properly since the changeover, I'd take it back to the shop that did the work and see if they're willing to make it right.
dcb |
I would love to do that but its been over two years! It never really worked, but at the time i was busy moving to virginia (from ny) and never had the time to let them have the car for a week or two since it was my primary vehicle.
Does the compresser ever turn?
How complete was the retrofit?
To be honest i am not really even sure how "complete the retrofit was, it only cost $400 and by the looks of reading other threads a well retrofitted system involves a bit more than i think they did. The compressor turns sporadically...
I'm betting you are losing the R134 from the system. I found and changed 13 o-rings when I did my retrofit.
Ok so i am reading the FSM and there is apparently a self diagnostic for the A/C system, does anyone have familiarity with this? I kinda follow it, but just wanted to see if anyone had experience with it.
Yet another question, if I have a supposedly retrofitted a/c system with the R134a refrigerant, do I now buy a R134a A/C manifold gauge set? Or do I get the R12 or a dual set up? I've decided i'll just tackle this on my own with hopefully some help from yall!
R134A has/uses different fittings, as well as refrigerant. How much is that set costing you?
well the 134a a/c manifold set is costing $40 from harbor freight...
http://da.harborfreight.com/cpisearc...fold+gauge+set |
Great deal!
I just ordered that set for my home shop.($48.98 with shipping) Now I need the vacuum pump.
looking to get that too! $20 for the pump
