Swap help
Hey guys, I just picked up a 92 svx. The car runs rough, and sometimes stalls. The trans doesn't really shift right. I am guessing it runs rough due to a bad cam angle sensor, or crank angel sensor. I am also suspecting the TPS, and the trans fluid being low. Let me know if this makes sense. Also, does anyone know exactly what you need to do a 5 speed swap?
I have an 02 wrx transmission, crossmembers, driveshaft, rear diff, flywheel clutch. Other than the master, slave cylenders, and pedal set, what else is needed. Thanks so much. Brandon. |
Go to How To documents then transmission........
HENRY 92 SVX Claret(No More) 12 Camaro ZL1 89 Yamaha FJ1200 07 Yamaha FJR1300 "GO RAVENS" |
Ok, now how do I know if I have awd or not. I havn't got a chance to look at the car. I don't know what trim it is...
If it has a sunroof it is AWD. If there's no sunroof look under the rear end for the rear diff.
I can has teh sunrooph in mi fWd SvX
bLAh
its a 92..its awd. fwd was only offered in 94-95
Youlll need the tranny, tranny mount, clutch,shift linkage, flywheel, pedal assembly, master and slave cylenders (If hydrolic) and a starter The crossmember, shift linkage, and pedal assemblies wll need to be custom fabricated using parts from the donor car, and the svx driveshaft will need to be extended. If this is a job your unsure about doing yourself, shoot Tom'sSVX a pm about a 5 speed kit. It comes with all the parts youd need to make, and he offers rebuilt / extended driveshafts as well
R.I.P Cool Signature. You're gone but not forgotten. I mean, sure, I kindof don't remember some of the finer details..but I remember you were funny, and at one point you said spaghetti in Dutch....but definantly not forgotten |
you guys have been amazingly helpful. What all does the kit come with and how much are we talking? THanks
Brandon. |
Here's Tom's profile: http://www.subaru-svx.net/forum/member.php?u=2184
Fire him a PM to set up the kit. I think it's $800?
