Old 12-14-2013, 12:52 PM
SUPER SUPER is offline
oil leak on top of motor
I have a slow (I think) oil leak on the top of the motor. Can't see where it is coming from, but oil is pooling in the engine crevices. Occasional oil drips on exhaust create an odor too. Ideas?
Last edited by SUPER; 12-14-2013 at 03:53 PM. Reason: fix typos caused by posting by phone
Old 12-14-2013, 01:00 PM
WhatIsThisIDont's Avatar
WhatIsThisIDont WhatIsThisIDont is offline
Re: oil leak on top of motor
Long time EJ22 user (and occasional abuser) here. I'm not sure if it's the same for the EG33, but the 2.2 had an oil sending unit directly under the alternator. If it's oil, then that would be where I would start checking.
Again, not at all sure, but still trying to connect dots between my favorite Subie engines.
Old 12-14-2013, 01:04 PM
wdb wdb is offline
dances with roads
I replaced the PCV valve on my SVX to cure the oil pooling on top of the engine. It's on the bottom of the intake plenum and a whole lot of fun to get at. If you end up taking the entire intake manifold off, as I did, go ahead and replace all the vacuum lines under there, and both knock sensors bolted to the top of the block, while you're there.
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 12-14-2013, 03:55 PM
thanks for the input. Will need to remove intake to get to it I'm sure. I will order the parts and take advantage of the opportunity as long as I am in there. Just looked and the sensor is $100 each on subaruparts.com. wondering id I should just let them be as the motor is running great. How often do these go bad? I have about 180K miles on her. I assume they are original, but not sure.
Old 12-14-2013, 04:18 PM
You can go aftermarket on the knock sensors. They run $10.00 and up. Beck/Arnley around $45.00
Old 12-14-2013, 05:08 PM
Any. recommendation on where to purchase? Web site?
Old 12-14-2013, 07:36 PM
this is a great deal:http://www.ebay.com/itm/KS86-Knock-S...b209c0&vxp=mtr $15.79 Rock Auto sells the same one for $35.79 plus shipping.
Old 12-15-2013, 09:38 AM
Knock sensors can not leak oil.
If you remove your intake manifold be VERY careful not to break the nipples on the electrical valves/switches.
Strait hose is fine for replacement.
You should also replace the O-Ring under the I.R.I.S. valve.
No, you can not get it from Subaru,
but I have them for $5.00 each.
Old 12-15-2013, 11:27 AM
I'd check to be sure that the 50 cent O-Ring under the PS Pump Tank isn't your problem, as that is super common issue, and leaks on top of the motor....just what I would check first.....cheap and easy fix, if that is what it is...
Old 12-15-2013, 01:50 PM
IRIS? what is that? Next to the Johnson Rod? And the knock sensor replacement is , I think, a suggestion to take care of something in a preventative fashion as long as you have the intake off. I don't think anyone suggested that is where the oil was coming from.
Old 12-15-2013, 02:49 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
http://www.subaru-svx.net/photos/user.php?svxfiles|24710
16195AA030...Check Valve...$21.08
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 12-15-2013, 03:38 PM
IRIS
Intake Resonance Inerta System.
I only change the $100.00 knocksensors if they are bad, or cracked knowing that when cracked they will go bad.
As far as the johnson rod
GFYS
Old 12-15-2013, 08:35 PM
IRIS valve o ring. OK. Thought u were pulling my leg.
Old 12-15-2013, 09:21 PM
92 SVX 92 SVX is offline
I have never changed my knock sensors, but I helped a friend change the passenger side one, we were able to take it out without removing the manifold but it was a fun little *****.
The iris valve is one reason these cars have the power they do, its a great system.
Old 12-16-2013, 08:14 AM
The drivers side is even MORE fun to change.
I can now do either side in 45 minutes.
Having said that Young Tom would be done by now.
sigh...
