Old 01-05-2011, 04:57 PM
Red94Svx Red94Svx is offline
octane in my svx
What will happen if i just put regular gas in my car vs. 92 octane?
Thank you
Old 01-05-2011, 05:16 PM
ZMan's Avatar
ZMan ZMan is offline
Re: octane in my svx
http://lmgtfy.com/?q=What+will+happe...+92+octane%3F+
Old 01-06-2011, 08:54 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
I own or have owned 7 and have never used anything but regular gas in them.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
20 F150 4X4 King Ranch
FREEDOM IS NOT FREE
Old 01-12-2011, 06:58 PM
jlhamblin jlhamblin is offline
Thank you
I've tried 87 oct, & 89 ethanol blend & 91
87 ran terrible, car surged & shifted weird
89 ran better but got terrible mpg's, like 19=20
91 was fine, 24.5 mpg run good
waiting to try 110 from race car just for fun !!!
let me know how you do
Old 01-12-2011, 07:17 PM
Lee
Keep THAT up Lee and you will just blow the head gaskets right out of them!
Just kidding.
Old 01-12-2011, 07:21 PM
My SVXi don't even like the "required" 91 octane, they run better and get much better mileage on 93 and still good when I have to use 92. Almost all local stations here have 93 octane for premium.
Old 01-13-2011, 02:31 PM
subbieatnz's Avatar
subbieatnz subbieatnz is offline
I used to use 97 in mine. Sometimes I would use 95 if I couldnt get 97.
1992 NZDM SVX Maroonish Red/Black ( 1st car ive owned with an cd player ) Has been retired
1989 Vortex 6 Maroon
1983 RX Silver Grey
1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration
Old 01-13-2011, 04:38 PM
LetItSnow's Avatar
My 10th Subaru is a WRX
I wish I had such troubles. We used to be able to get 94 around town, but the best I can find is 93 now.
Old 01-13-2011, 04:52 PM
92 SVX 92 SVX is offline
While it looks impressive subbieatnz is in new zealand and they rate the octane differently, or should I say the USA rates it differently because most of europe also rate differently then we do.
I read an article about it, if you look at the gas pumps they should say octane R/M method I believe they only use R method. The higher number they get is still about equal to the gas we get.
This is not an actual comparison but I would say there 97 is about equal to our 93-94 rating.
Old 01-13-2011, 05:49 PM
zymmer4 zymmer4 is offline
I have to use premium to make mine run well..I had to put a half tank of Plus in once..It didn't run smoothly .
Old 01-13-2011, 06:00 PM
I used to use 87 or 89 it ran fine I lived in ND where there was only 87, 89, and 91 available and the price difference was way too much for premium, now I live in jax fl and 93 is availabe and only about 20 cents difference I notice better power and way better fuel economy using 93. I dont have numbers though.
Old 01-13-2011, 06:09 PM
taylorbr's Avatar
taylorbr taylorbr is offline
The SVX only uses high octane to prevent detonation because of its compression ratio. I would think that with the age (and mileage) most of the fleet is at that lower octane fuel could be used without the engine having to pull timing (and subsequent loss of power and efficiency).
'93 Legacy LS (will last longer than the cockroaches)
'94 SVX LSi
Old 01-13-2011, 07:37 PM
Cam Cam is offline
Most engines probably have suffered from a slight compression loss, like stated above. Also, the air density matters as well. High elevations will take less air into the cylinder making the car run rich. So high elevation cars should run fine on slightly lower octanes as well.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE .256 duration intake/exhaust cams
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 01-13-2011, 07:55 PM
Huskymaniac's Avatar
Uses the ignore feature
Maybe we should run regular and add Toluene or Xylene. It would keep the fuel system clean and boost the octane.
Tony
Old 01-13-2011, 07:57 PM
Cam Cam is offline
I wouldnt do that without buying some seals and dumping them into a bucket with those chemicals. Probably not a good idea. I heard of someone using acetone to get better fuel economy. But that's the kind of thing you do with a rental vehicle.
Cam
'92 Ls-L Dark Teal
