Old 04-13-2010, 12:42 PM
nexus_7 nexus_7 is offline
Everyone talks about it, but how the hell do I do it?
Repack bearings. I got new ones from Timken right here. Do they come apart? I am at a loss.
Thanks in advance!
Greg
Old 04-13-2010, 02:06 PM
pearlm30's Avatar
pearlm30 pearlm30 is offline
Re: Everyone talks about it, but how the hell do I do it?
Check my locker on rear wheel bearings. Good luck
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 04-13-2010, 02:28 PM
Ironhydroxide's Avatar
Ironhydroxide Ironhydroxide is offline
SVXT6 Project
Make sure your hands are clean, and you are in a Non dusty environment. Take some of the Bearing grease and place it in your non dominant palm, near the edge, take the Bearing with your dominant hand and press the wide side of the bearing (taper bearings, like wheel bearings, are easier to pack from the larger diameter side) into the grease repeatedly until the grease has come out of the smaller diameter side of the bearing as well as around the rollers, Rotate the bearing (The ENTIRE bearing, not spin the bearing) and repeat until the entire bearing has had grease pushed up through. then install the bearing and make sure your dust caps get pressed on tightly.
SVXT6 (Pearly) just got running 201,000 (body) 105,000 (engine)
Honda FT500 Ascot [Red]
Old 04-13-2010, 03:50 PM
So, I pop out the inner plastic thing then it come apart?
Old 04-13-2010, 04:25 PM
Yea, just pull that little plastic thingy ring out, and they come apart.
Old 04-13-2010, 04:51 PM
SVXT6 Project
Just make sure you don't pull the outer and inner race too hard, you don't want your new bearing to disintegrate. but the seal ring should come out (that is if it has it).
Old 04-13-2010, 05:15 PM
that thing seems rather stuck in there. can I put force behind it. I have a socket that fits right on it and can put some power behind it...that ok? or is that a bad idea?
Thanks
Old 04-13-2010, 05:31 PM
SVXT6 Project
If it is a Seal that seals the outer and inner race, If it is not a seal, it is the Cage which holds the rollers in their proper placement. so, if it is apparent that it doesn't seal dirt from getting into the Rollers, then it is just the Cage and go ahead with the packing of the bearing, If it does seal it, some have taken a very small drill bit, drilling a hole through the seal on one side, and using a pick, or even a grabber screw to remove the seal.
