Old 09-03-2007, 10:27 PM
nightrider nightrider is offline
Whinning noise during acceleration???
does any one elses svx whine when they are on the gas? people ask me about it n i dont kno wat to tell them i here its normal
Old 09-03-2007, 11:02 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Tom's does, but that's a good whine
It's probably your steering pump. If so, do a search on the O-ring replacement. It's the best $1 you'll ever spend (unless you're at a strip club in northeast pennsylvania)
Brian
Old 09-04-2007, 02:02 AM
Nomake Wan's Avatar
Nomake Wan Nomake Wan is offline
Retired
Send a message via AIM to Nomake Wan Send a message via MSN to Nomake Wan Send a message via Yahoo to Nomake Wan Send a message via Skype™ to Nomake Wan
Does it sound like mine?
http://www.subaru-svx.net/forum/showthread.php?t=40027
I found the videos of my old '90 Legacy doing the same thing, I'll have to upload them soon...
Old 09-04-2007, 08:02 PM
beilive it or not my power stearing pump was just replaced because it went so it is all new with all new orings, the noise was the same before and after. toms is super charged right(im kinde new so correct me if im wrong) i wish i had that same whine
Old 09-04-2007, 09:08 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Is that only happened after at certain speed?
It could be from the drivetrains, tranny or front differential. Check the fluilds' conditions.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 09-04-2007, 11:03 PM
ssnsltd's Avatar
ssnsltd ssnsltd is offline
That's gona leave a mark.
loose Heat shields caused mine to make a slite whiine durring take off.
David
96LSi 102k Laguna Blue
95 LS-L AWD, Safety package, 140k Polo Green
the Chick Magnet:
91 Justy GL EFI 4x4 154k (new motor @120k)
90 Yamaha V-Max
82 Yamaha XJ650LJ Turbo
My Diver Propulsion vehicle:
88 Jeep Cherokee 160k
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
85 XT AWD/4x4 Turbo Space Blue
Old 09-05-2007, 02:19 AM
Nomake Wan's Avatar
Retired
Updated old thread with more videos, non-SVX but I wonder if it's the sound you're referring to.
http://www.subaru-svx.net/forum/show...9&postcount=12
Old 01-28-2010, 09:02 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Whinning noise during acceleration???
Ok so heres my issue.....
When I step on the gas now, I hear a noise that very muffled, and the best way I can describe it is... like an RC car motor, or a coffee grinder, or compressed air being blown into a garden hose.... something like that. Its very muffled and only happens as the throttle is pressed. The noise increases with more load on the engine..... but I can only hear it at slow speeds or from a stop.
Front diff? Checked oil level, its just above the low mark.
This didnt come on gradually, I just one day noticed the noise.
Old 01-28-2010, 10:17 PM
Gamesy's Avatar
Gamesy Gamesy is offline
first guess is alternator whine. try doing it with the speakers off
Old 01-29-2010, 08:33 PM
Stilor's Avatar
Stilor Stilor is offline
I had similar symptom with '00 Outback some time ago; it turned out to be a muffler that rusted through - the air escaping from it made that sound.
Park, shift to neutral, step on gas and have somebody walk around your car listening - the perception of where the sound comes from could be different when you're inside.
-- Alex
1996 SVX LSi "Used To Be Black"
2010 Ford Expedition XLT EL 4x4 "Silver"
Old 01-30-2010, 09:11 PM
Banned
I've got the dreaded whine every now and then it's my alternator if that helps... I'm getting a high output alt as soon as I get cash..
Old 01-31-2010, 07:34 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
I sometimes hear whining when I step on the gas hard. It usually happens when my mum is in the passenger seat.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 01-31-2010, 10:26 AM
sowise sowise is offline
haha that is funny b3lha...
I had a bad gear whine in my 74' plymouth it even ended up affecting the stereo and was consistent with throttle position.
For the stereo it was a grounding issue, the gearing was a combination of harmonic vibration (I believe) and a gear oil change as well as fixing bushings so any vibration wasn't transfered to the chassis by poor bushings and bad rubber.
There are alot of places in the SVX where the rubber is worn out, this could cause more of a metal to metal contact and may be some of what you are hearing. Also tires can cause alot depending on tread. Good luck.
Old 01-31-2010, 11:15 AM
StelthSvx's Avatar
StelthSvx StelthSvx is offline
Whining During Aceeleration>>>>>> sounds like my wife!!!!!!!!!!!!! Thats what the O-sh;it handle is for!!!!!!!!
92' Claret LSL 282,000 miles 1owner(ME)
07' Pearly WRX 40k Cobb Stage II (sold)
SVX+$$$+GreaseMonkey =
