Old 01-04-2010, 10:29 PM
Alcyonedrvr Alcyonedrvr is offline
svx trans swap
i am swapping my svx trans for an automatic out of a 97 impreza, also the rear end to match the gearing. i need to know if and what axles i can use to fit...the svx axles have a different size bearing, the rear end i'm assuming is limmited slip, so did any come without, that will have the smaller outer bearing and still be long enough?
thanks
Crash aka ben
Old 01-05-2010, 05:47 AM
Re: svx trans swap
1. The search buton is your friend.
2. If you have not used the search button then you do not know that
the 4.11 that you are thinking of installing can not compare to a 4.44.
3. The how to is in my signature.
