WTB:Right rear beige leather seat
Apparently the sun is doing a job on my car. One of the seams popped. So I either need to buy a replacement or repair the seat.
Re: WTB:Right rear beige leather seat
I have one; - but the condition has to be checked; partstogo@gmail.com
Dan sr; |
Does anyone know if a non-split rear seat can be installed in a car with spli rear seats?
Don't see why not. You'd just need to take out the hinge bracket in the center. The part that holds the trunk carpet on the back of the seats will also be different, and I'm not sure how interchangeable, so best to get that grey plastic strip as well.
Come to think of it, maybe there's something different about how it attaches at the top. I don't remember whether the non-split seats have 2 buttons at the top for the latches or only 1.
Yes. They can be interchanged no problem.
The one-piece seatback uses one release button, located under the passenger's side headrest.
From 1994-1997, only the LSi (leather) had the 50/50 split rear seat. The L and LS models all had one piece. At least in the U.S., I have never seen a cloth split rear seat. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 06-25-2012 at 12:40 PM. |
