Adjustable Rear Lateral Links
Yes, they are here... Pics to come later today
Tom |
Re: Adjustable Rear Lateral Links
Custom or from an STi/WRX?
Megan links?
They are whiteline adjustable for the STI. I was able to get my Dealer parts supplier to send me a pair for test fitment. I will be ordering another pair for the other side of Shotgunslade's car. Got them mounted and with a little work everything fits perfectly. I am debating getting some Cusco pillowball trailing arms for his car as well but feel the adjustable lat links will be more than enough for suspension stability and adjustability.
Tom |
I have the Megan Racing lateral links I haven't finished the full fit up since I have been busy on pretty much everything else. I have to replace my backing plates before I start reassembling. The lateral links will work though and I have the trailing link as well. The adjustable trailing link may need some slight modification but nothing too major. I look forward to seeing what others are doing though.
I figured the STi links would be a bolt on. Good to know!
I'm guessing those were the ones that Jackie had on the shelf ![]() ![]() -Bill
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 12-13-2009 at 07:22 PM. |
Pics are loading Tom |
![]() ![]() ![]() ![]() ![]() ![]() Tom |
Looks great! I wish my subframe looked like that. Maybe not gold, but that clean anyway...
Wow, that looks great and you even have Nevins sway bar in there which looks really good with the lateral links. I am a bit jealous of the rear subframe too. I took the cheaper route using a grinder and some engine block paint (gloss black) it looks ok but not like a smooth powder coat.
![]() Quote:
1992 NZDM SVX Maroonish Red ![]() ![]() 1989 Vortex 6 Maroon 1983 RX Silver Grey 1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration |
Look at the picture of the installation instructions with the part number across the top ![]() Ouch Tom. Upon further digging, whiteline's website gets $300 PER SIDE for the KTA107 adj. links. It's a needed upgrade, and with Nevin's swaybar on the way I was thinking about it, but $600 on lateral links seems a little excessive to me... ![]()
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap |
Lets just say I got a good deal on the lat links. Considering the failure rate of the original bushings in other SVX I have had apart they are absolutely needed for a car ready to hit the track. Not to mention the adjustability of camber and rear wheel toe is an added plus
![]() Tom |
$600 for the full set is fairly standard for those, the Perrin ones list for $560 or something. If you're going to be tracking the car on a regular basis you have to be ready to spend the money on it.
