Brembos on an SVX!?!?!?
Yeah, I am doing some searching on Nasioc and I am asking my Canadian 6mt connection for an extra caliper both front and rear and an extra rotor to see if the brembo are a direct bolt up. I know these brembos are not great but they are better than what we have, not to mention, if they do work that will open up our brake aftermarket 300fold. Anyway I will keep you all updated as soon as I know more
Tom |
That'll be GREAT! You're right on with the expansion of our brake options. Sent a PM about your 6mt hook up.
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs! Sand Diego SCCA Solo 2 #308 RIP 84 VW Scirocco 02 WRX 88 XT6(regret the day I left her behind) socaleuro.com They like the flat 6... Check My New Homepage.. |
Damn! ...and I thought I was going to get to pioneer this swap
Maybe I'll beat you to it, Tom
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto. 1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong! 2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver. 1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver! 2007 Honda CR-V, some awful shade of light green *yawn* 1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED. 1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust* |
I don't know how much a WRX brake swap would cost but for those interested in a monster upgrade with 330mm or 355mm front rotors and four-piston or six-piston Wilwood calipers front and/or 325mm rotors and four-piston calipers rear check out the SVX section in the PDF file HERE.
Of course these aren't cheap, you could probably buy a used SVX for the price of a Wilwood brake kit. |
Sti brake swap can vary from $500-$700. Then add the price of rotor resurfacing or new rotors, then pads
Tom |
Tom,
PM Tom the Elder....my guess is that you'll run into similar issues.... -Bill
Tom's kit is very economical. If these calipers require adaptor plates I may try to make them but I doubt it. If they don't directly fit I may scrap the idea. I am just looking to put the Maybes to rest once and for all
Tom |
Tom, understood...my guess is that the Brembo calibers will need an adapter plate -Bill
I understand that as well. I may be able to draw up a cad design and have custom ones made... but they would be one offs and nothing more. I am basically looking to see if there is a cheap and easy way out of these crappy 2/1 piston calipers we are cursed with
Tom |
if it helps at all the rear calipers on the svx appear to be the exact same as the rears on my 97 AWD legacy sedan with 14" wheels. I can't remember if the brackets were different... but the calipers def look like a direct swap... if that helps at all
they are a direct swap... But it's the fronts I am more concerned about than anything.
Tom |
A reasonably priced Big Brake Kit for an SVX??? That anyone can install!!! Without even bleeding the system??? THATS JUST TOO GOOD TO BE TRUE!!! Oh, wait
ladies and gentlemen allow me to introduce Tommy Two times.... say hi everyone!!
Tom |
