Old 01-31-2017, 08:47 AM
svxash's Avatar
svxash svxash is offline
Is 5w-40 oil alright to use?
Is a 5w-40 weight oil alright to use in my SVX? I don't believe that weight was around when our cars were manufactured so there's no info in the manual about it. I'm looking at the full synthetic Rotella T6 5-40. We use it in our 05' Baja turbo and have had great results with it.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 01-31-2017, 06:56 PM
92 SVX 92 SVX is offline
Re: Is 5w-40 oil alright to use?
That is what I use in mine, its full synthetic and it has properties that meet the requirements. is it ideal not likely but it doesn't hurt and its cheaper then many of the "good" full synthetic oils that would be better.
Also I look at this these cars are many years old now unless you rebuilt the engine the tolerances are probably looser then stock so that thicker oil will help
Old 02-01-2017, 07:44 AM
Unless you're in the Arctic, go for it. I run either the 5-40 or 0-40 T6 in my Legacy, depending on what's on sale. With blessings from Blackstone Labs I've been able to push my oil change intervals out to 10,000 KM (6000 miles), so between that and buying oil by the barrel I've managed to save quite a bit of money with Rotella.
Old 02-01-2017, 08:03 AM
svxash's Avatar
I've never seen the 0-40 before. Where did you purchase that?
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Old 02-01-2017, 12:16 PM
I am not sure of 0-40, I tried some Mobil 1 Euro 0w40 and it seemed that the svx started making a slight noise I ran it for 5 miles max and drained it and put T6 in
Old 02-01-2017, 01:54 PM
Canadian Tire. I believe the 0-40 only comes in barrels though.
Old 03-20-2017, 01:44 AM
maxtian maxtian is offline
Been using 5w40 also and have no problems. The engine seems to like it.
Old 03-20-2017, 06:34 AM
The 0W-40 is a lot thinner when cold and flows into the tight clearances between the bearings, rings and oil passages of a newly rebuilt or newer engine. After breaking in my new engine with conventional oil (5 changes in 1000 miles) I started the 0W-40.
The Mobil 1 0W40. It is closer to a 10W30 than a 10W40 at operating temperatures. It has an excellent HTHS viscosity, so it shouldn't shear even in an STi engine under stress. It also has great low temperature viscosity for cold climates.
One other thing to note is that the Mobil 1 0W40 has a very high TBN value, which means it is great for extended oil change intervals.in my case every three years with only a filter change and new oil annually.
If you want some extra seal conditioners to hold off leaks on notoriously leaky Subaru engines, either blend the M1 0W40 with the M1 5W30 HM or add Lubegard Bio/Tech Engine Protectant to the M1 0W40 oil. I was not looking for the seal conditioners of a high mileage oil , which you may need.
The Lubegard product adds some seal conditioners and a special polar ester molecule that creates an additional protective coating on engine parts.
The added ester film on the metal surface will help avoid damage when you start the car after it has sat for a long time.
The recommendations were from Blackstone Labs, which does my used oil analysis. Along with consultations with Mobil 1 directly.
Old 03-20-2017, 06:43 AM
Old 03-22-2017, 02:22 PM
Huskymaniac's Avatar
Uses the ignore feature
Well done!
Tony
Old 03-22-2017, 10:05 PM
svxash's Avatar
svxcess,
Where's the best place to buy Lubegard Bio/Tech Engine Protectant?
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Old 03-23-2017, 06:35 AM
theflystyle's Avatar
svxcess,
Looks like Amazon has it, but its at a high price right now. Around $9 seems to be the usual sweet spot according to CCC.
https://www.amazon.com/Lubegard-3090.../dp/B0002JMLRE
1994 SVX LSi
2008 Legacy 3.0R
Old 03-23-2017, 08:14 AM
WYOSVX's Avatar
WYOSVX WYOSVX is offline
Running Mobil 1 5W-40 right now, 90-some thousand miles on the engine. Ran it for 10k miles last time and the old oil looks almost new. BUT, I'm not having my oil tested. So, all I can say for sure is that my car is still running well.
Weird coincidence, too, that I took a trip right after the oil change and got 28 mpg. Can't be the oil, right? Prior to that, I'd never recorded better than 24 mpg.
Old 03-23-2017, 08:42 AM
SVX_MY_BABY's Avatar
Cdn Tire actually sell 0-40 Euro Spec.in 1 litre Royal Purple, 1 L & 5L Castrol Edge and it's own 5L Formula 1 house brand.
I use the Castrol in my Audi A3, mainly because it's the cheapest when on sale. When Cdn Tire puts it 40% off it's less expensive than their house brand when it goes on sale at 35% off.
Peter
Old 03-23-2017, 08:49 AM
For what its worth, I going to be switching from traditional M1 10w-30 Full Syn to M1 high mileage Full Syn: (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1).
1994 SVX LSi
2008 Legacy 3.0R
