on the quest for those "perfect" rims
i think i found rims that i would buy.
it's a shame these don't exist in anything other than a rendered model. ![]() just stock rims, a couple inches more in diameter. ![]() ![]() it looks so good.
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive ![]() K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Re: on the quest for those "perfect" rims
I'm about to make your day
![]() http://www.subaru-svx.net/forum/showthread.php?t=54117 Go down to post number 10 and then read on for more info.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
Not the larger diameter you want but I have these if you are interested:
I like them but I'm not sure I love them on the teal. You could, of course, mount your tires properly and have them spin in the normal direction.
i have had to correct many tire places, telling them that my wheels are backwards. but i'm not interested, as i don't like the big tire look. i HATE the super thin tire look though. i really would like a pair of 17" rims, with medium tires. they just look beefy and tough, and ready to fight.
http://www.phenixwheels-store.com/se...95-1996/Detail
icing, you have made my day extraordinary. after a bunch of searching and using my savvy internet skillz, i found that they are 17" rims from the 1994-1996 Dodge Stealth, with subaru center caps. i know what i'll be saving up for. ![]()
Yep. And you know they'll fit, because someone's used them on an SVX before (a 4WS, no less!). And 8.5" wide
![]() I think that you'll have to do some modding to get the SVX centercaps to fit.
The shoguns may be a good option, too,
i really think i will be buying these as soon as i have the means to. i think my rims are a little bent, cause i can't get the alignment perfect, and they're peeling. these are awesome. and even wider! that won't rub, will it?
edit: found center caps :] http://www.wheelsandcaps.com/w_selec...lth&type=&id=3
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive ![]() K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. Last edited by B 4 You; 12-08-2011 at 06:28 PM. |
