Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Turbo Projects
Old 05-28-2012, 01:26 AM
bazza bazza is offline
Another Turbo EG33
Old 05-28-2012, 05:58 AM
immortal_suby's Avatar
Thread Killah
Re: Another Turbo EG33
Cool project!
Locker Link
2015 BRZ Limited 6MT
Old 05-30-2012, 12:41 PM
Originally Posted by bazza View Post
WRX turbo oil cooler setup, turbo oil return also pictured:
So how did you plumb the water lines to this thing? There are 2 water lines coming off of it, right? What did you connect them to?
Old 05-30-2012, 07:26 PM
Old 06-01-2012, 11:27 PM
smc smc is offline
eg33 drysump: http://www.wrxmodders.com/forums/viewtopic.php?p=260946
Old 06-02-2012, 01:02 AM
Dessertrunner's Avatar
bazza in your rebuild what piston, rods & bearings are you going to use?
Tony
Old 06-03-2012, 07:33 AM
Old 06-03-2012, 12:27 PM
Stock pistons, Manley rods and ACL race bearings.
Pistons should hold up fine for 550 hp with E85 - have so thus far with 100+ laps complete.
Stock pistons? That's kind of shocking.
Which ACL bearings are you going to use exactly? I know enough to know that I need two sets of EJ22 bearings but I haven't been able to figure out which brand/type of bearings are best. (Also the EJ22s there are two types of bearings - one with thrust bearing at #3 and one at another, but I don't entirely know what that means or which is right for the EG33.) I have ordered all the parts to build my engine except for those.
Old 06-03-2012, 08:17 PM
Old 06-03-2012, 09:23 PM
Shocking in what way, that I'm going to keep using the stock pistons?
Also I bought 2 x sets of EJ2X ACL HX bearings (3# thrust) for my big end. I also have a set of #5 thrust so I'll check everything and report back in detail.
Shocking that you wouldn't go for pistons that are stronger and lower compression. Some people who have broken EG33s with boost have had the pistons go first.
Thanks for the info on the bearings. These, right? http://www.aclperformance.com.au/us/...bearingsus.htm
What do you think for the rod bearings? Same?
Old 06-03-2012, 09:45 PM
92 SVX 92 SVX is offline
maybe I didnt read it correctly but I think he said he will use the stock 2.2 turbo piston. never mind i reread it he was just comparing stock to 2.2 turbo piston
Old 06-03-2012, 09:52 PM
Old 06-04-2012, 01:51 AM
bazza what did the bearing cost you also were did you buy them from?
Old 06-04-2012, 02:34 AM
Old 08-10-2013, 05:38 PM
BackWoodsBob BackWoodsBob is offline
he deleted all his posts?
:unamused:
