Two (nearly) complete cars!
I have two complete cars less the transmissions and engines. I will sell any part of these two cars.
Black 1992 was used for a engine swap by the person I purchased the car from. It is the most perfect svx body I have (out of 4) without a scratch. It is black and the paint is good. The car had few miles and spent its life in a garage. The (grey) interior is excellent. Heater core, axles, brakes, wheels, windows, hood, trunk lid, headlights, maybe a taillight (we all know they crack easily and like moisture), sunroof, sunroof motors, you name it. I cannot list every part this car can give. I have taken the cv joints and rear axles. Rear dif is still intact, driveshaft, engine and tranny mounts, etc. Green 1992 was bought for the use of its good tranny. Engine needs a head gasket done (give me 3 months to get to it) tranny has been taken out. Other than that, it is a very nice car. Interior is very clean for the age (not as perfect as black car, which is a time capsule) with no tears in the grey leather and good suede trim all around. Axles, brakes, wheels, doors, hood, drivers fender has small dent every other body panel is for sale. Both of these cars are available as rollers or for individual parts. If you want the whole car hurry before people start taking the good stuff. I have pictures of everything and access to all parts throughout the work day. Ask away!!! Thanks, James Butler |
Re: Two (nearly) complete cars!
parts pm sent
A shame to sell the black one in parts...
If I could I would buy the black car whole.
The black car had its heart ripped out by the previous "owner." Its tranny has the famous 1-2-oh wait where's 3rd? the same as my 97 red. The (engine) electronics are gone, engine harness etc. No accessories. The electric window's, etc. remain intact. Sunroof motor also has been taken (I still have one from the green 92). It was an engine swap and thus needs a new engine with everything to be good again. If you need an ebony body part/shell, this is the best one you'll find. Not a single spec of rust, the door(s) makes a perfect solid connection every time you shut it, smoother than any of the other three I have. It is just a great shell. Silver is absolutely right. Somebody should snatch up this shell because it doesn't need a thing. Maybe has two door dings all the way around.
The shell of the green car is good, minor damage to driver fender and hood, an automatic fence got the better of it before I acquired the vehicle. I pulled out the dents and spent a few hours (ok, days) trying to make the fender straight. If you want to learn bodywork try fixing an svx part. Thin steel and no straight lines. I digress...long story short No rust. The red 97 tranny also has a cracked rear driven gear, which is housed in the rear of the tranny and is a hard part. I actually have 3 tranny's that need good guts. Any swapping, etc. would be welcome!! Current status of 97 red is a tranny that worked (from green 92) was put in. The car ran and shifted great. A week later neutral became its favorite gear. It never changed its mind. In fact it decided never again to engage forward, reverse, or any other way for that matter. Just like my ex wife.http://www.subaru-svx.net/forum/images/smilies/lol.gif All other systems in car work perfectly. This car is not for parts. And if anyone know's why a 4EAT would go front drive, not the fuse, etc. default, but a failure somewhere resulting in front drive only, please let me know. All three of these cars are available as rollers at any time. The red 97 has a rebuilt title from the state of MA. Title of black shell is clean but no longer exists? Not sure what you might have to do to re-title the vehicle. Green 92 has salvage title. And yes I have it. Only title I do not have is the black 92. |
Did you ever try putting the transmission in the "1" position? It is possible that it will move when doing that but even so, the trans will more than likely need a rebuild/replacement.
Yup, tried that. Also tried putting in manual and starting in 2nd. And changing out the valve body. And the solenoids. So I'm going to agree with you on that one...thank you for the reply. I do have a good tranny shop locally that can provide all parts(and yes I've confirmed this), so once I get moving I should have no trouble.
Do you have rims that are straight and in decent condition?
Yes. I have original rims in original grey I can take a few pictures tomorrow. I have 2 extra sets I will check on the condition of all 8 wheels. The worst wheels might have minor paint chipping around the corners, but I know there are 4+ clean wheels.
BTW nice low mileage LSi. My 94 is that color. I have a center (between the headlights) piece for the front that is painted that color with the Japanese alcyone symbol in the center. The person before me was apparently an enthusiast (and not a mechanic lol). Last edited by SVXAHOLIC; 11-09-2010 at 10:48 PM. |
After looking at the center piece (yes, its a "97" version) it is 75-85% breathable. I can see the condenser and radiator through the piece, I am sure that a 2x8" opening adds some air-flow. Also the green paint on the center piece has a few bubbles (prev. owner's spray job)
Is the radiator available? Was on my way to work out this a.m. and suddenly, steam from the front end. Looks like the top tank has cracked right under the pressure cap.
hello.
i need the connector betwen the pipe and the P/S pump. subaruparts n° 34415AA041 and need to be send to france. paypal friendly. thanks. |
Looking for an IRIS valve, or the manifold for that matter and a throttle body.
