2 or 3 Os sensors, OBD1 or OBD2 for 1997 Canadian LSi?
I have a 1997 (build Oct 96) Canadian spec SVX that has very few problems. In the course of correcting them both my Service Manager and I have some confusion.
After much deep-diving research in the Forums I 'was' under the impression that I have 2 pre-cat O2 sensors and Subaru added a 3rd after the cat for 1997. I was also under the impression that 1997 SVXs with the OBD connector behind the door on the dashboard were OBD2. Those with the connectors under the kick panel are OBD1? Perhaps all of this only applies to California spec SVXs? The Mechanic's first OBD check for the engine light on was done using OBD1 after he found and fixed a broken wire on the dash connector. It was slightly less than conclusive and at $89/hr I'd like to give him as much help as possible. I was in having the AC system evaluated. Please, someone who knows for sure or has hands on experience please set me straight on this puzzling contradiction. Thank you.
1997 Ebony Black Pearl LSi, 80k miles (129k kilometers), JDM clear corners. 1994 Laguna Blue Pearl LSi, 149k miles (249k kilometers), blown tranny, likely using bits and selling as donor transplant project. 2006 Newport Blue Outback XT Ltd 117k kilometers, lowered 2.25" on OEM Legacy GT suspension. 1994 Emerald Pearl LSi w 2006 WRX 5 spd manual. 1997 Laguna Blue LSi, 46k miles (73345 Kms). One owner 25 years, always garaged, pampered and 9/10 showroom condition. Possibly the last Canadian spec Laguna ordered #100134 |
Re: 2 or 3 Os sensors, OBD1 or OBD2 for 1997 Canadian LSi?
1996 and 1997 SVX's are all OBD II cars. There is a 3rd o2 sensor on top of the exhaust pipe by the end of the transmission. Its wire connector is on top of the heat shield, rather well hidden.
OBD2 SVXes only exist in the USA. The rest of the world didn't get them. Basically if it has an OBD2 socket then it's OBD2, otherwise it's not.
Partly confirmed by my Norway MY96 which has OBD1 (with ports and whatnot in the kickpanel left side).
I got my girl, I got my glass, I got my car and I'm ready to f... |
According to the attached PDF OBDII was required in Canada in 1996 as well
current stable, subject to change without notice: 1995 Red SVX, 4.44 & Quick Change 2014 Nissan Titan S 4X4 1992 Teal SVX parts car |
Thanks for that, steamer99.
And to everyone for your valued input. It's easy enough to guess but better to actually know. Between this group and SVX World Forums the true answer to this niggling question is emerging. Here's the thing - although my '97 SVX has all original body stickers intact, the underhood Emissions Declaration makes no mention of OBD. But, it has the two black OBD connectors under the kick panel as well as the 16 pin OBDII socket in the dash under the flip up door. I took possession of the car with the engine light constantly on with no effect on performance. The CEL would go out again for short periods during gentle city driving but came back on under spirited hiway runs. Diagnosis at the dealership threw out the code for a right O2 sensor and the MAF. This after a lengthy and somewhat shifty/dubious explanation that the shop had to use 'outdated' OBDI software. They were, of course, only too eager to change those parts for me at great expense. :-) Not gonna happen since the engine is running top-notch as is. Back home in my own driveway, armed with intuition and the wealth of information from the site, changing the green cone intake filter back to the OEM airbox & paper filter, and giving the MAF a good cleaning of K&N oil contamination, the CEL has stayed off the past week. I believe the EGU is gratefully relearning to run on 100% 94 and 91 octane rather than the 89 mix it was getting before. I intend to keep this car for the rest of my life. Due to its relative rarity up here in Canada and gradual natural withdrawal of support from Subaru North America I have been gathering every scrap of technical information I can find off the web and sticking it all in a 3-ring binder for myself and subsequent owners. I didn't know squat about OBD but I'm learning fast. To this end I have located a good basic OBDII scanner reader through Amazon.ca (sure wish I had an address in the USA). I'm looking forward to getting my own readings should the CEL begin acting up again and having the ability to clear old codes/resetting the CEL without having to sip bad coffee at a Dealership. After Labour Day when my work schedule drops from 60 hour weeks to 40 I'll get this Canadian car up on ramps and be able to determine if in fact I have a third O2 sensor to be concerned about. As stated above - It's easy enough to guess but better to actually know. First things first, tho. Next week the new AC Condenser rad gets installed and that will be very cool...
Evidently, you can read and reset any codes yourself without a proper monitor.
http://www.subaru-svx.net/forum/showthread.php?t=60271 I can add that I will clear my code and check if it comes back. All in all...what changed from day 1 to day 2? a) I had an oil change b) I went offroad and the front underbelly hit a stone at very slow speed. When I got my SVX, it did 80 kph at around 1500 rpm on the highway, maybe 1850 rpm @ 100 kph slightly uphill. Not so anymore, hardly under 2000 these days. What are your numbers?
I got my girl, I got my glass, I got my car and I'm ready to f... Last edited by jetboy; 08-18-2012 at 12:55 PM. |
Not if the car is OBD 2. OBD2 was US/Canada only for the 96-97s.
You can reset the obdII, however it will not pass smog for at least 60 miles as it needs to relearn itself. There is a good chance that it will bring back the cel that you wanted to eliminate.
Simply disconnect the negative battery terminal. Step on the brake pedal for 5 seconds. Then, with negative still disconnected, tap the negative lead to the positive terminal. This will reset the ecu and clear any codes stored. Reconnect the negative lead and your good to go. |
Yup. Thats them. There are 2 short lead sensors (right and left bank front) and one long lead for the 3rd sensor behind the transmission.
