Old 02-27-2006, 12:50 PM
chaswiggins chaswiggins is offline
Prepping my 4.44 Outback trans/diff for swap...
Okay so I have my transmission from a 97 Legacy Outback and the rearend with the 4.44 gears; my question is this...
What prepping do I need to do to make my job easier swapping out my SVX trans.
-The Outback trans came with no fluids...should I fill the trans before I put it in or after?
-The Outback trans had two metal lines cut, should I simply unbolt those lines from the trans or shave them down and flare them?
I know I have more questions. Any help would be great.
1992 Subaru SVX
2000 Daewoo Lanos
2001 Parts in my garage.
KYR SCCA member and Rally Driver wannabe.
Old 02-27-2006, 02:02 PM
Wait until it is installed to fill with fluids, don't want good atf pouring out of the tail end while installing.
Unbolt the cooler lines from the SVX trans and put them on the 4.44 tranny. Don't bother trying to slavage them
Old 02-27-2006, 02:56 PM
What He said.
And remove the rubber mount for the OB shift linkage, the SVX cable bolts directly to the case.
Remove the OB rear exhaust hanger, the SVX is different.
Remove the two wire speedometer sensor, as you have to use the one from the SVX.
When you go to install the new transmission, make sure to grease/anti-seize
the center of the flexplate, where the centering lug on the torque converter goes, and the locating pins in the transmission bell housing, located at 3:00 and 6:00.
And make sure you have at least one (but not more than one)locating pin per side.
Remove the OB rear trans mount, as the SVX one is different.
And MOST IMPORTANT OF ALL,
MAKE SURE YOU KEEP SPINNING THE TORQUE CONVERTER AS YOU INSTALL IT, SO THAT THE FOUR MOUNTING LUGS,(the ones the TQ bolts go into) ARE ALL THE WAY SEATED.
You can tell that they are in far enough, IF the transmission side of the lugs are about 1/2" into the bell housing.
And when you install the trans, keep checking the TQ to make sure it still turns freely, even after you bolt the bell housing tightly to the engine!
If it quits turning freely, STOP, the TQ is probibly not in far enough!
Tom.
Old 02-27-2006, 02:59 PM
Oh, and about those lines, the one that goes to the front of the transmission has a ball bearing check valve and spring, along with the two aluminum gaskets, so be careful how they come out.
Old 02-27-2006, 03:18 PM
yeah, that was a nice little surprise the first time I pulled them
Old 02-27-2006, 03:37 PM
thanks a lot people.
Oh I was also curious if taking out all four axles, completely, was necessary. Could I just leave them hanging in place? (<Maybe a stupid question?)
Also, check out this trans jack I just bought for the swap. I hope this make things easier!
http://www.harborfreight.com/cpi/cta...temnumber=3185
1992 Subaru SVX
2000 Daewoo Lanos
Old 02-27-2006, 03:43 PM
I allways leave the rear axles in, and have not taken out the front axles, although the drivers side front axle can be a pita.
Without a decent trans jack you are boned!
Have you read, and reread all the 4.44 info?
Old 02-27-2006, 03:50 PM
Yeah I've been reading night and day on this swap. The search field has become a close friend of mine.
Do you think the jack I bought from harbor freight will suffice? It has a load capacity of 800lbs.
1992 Subaru SVX
2000 Daewoo Lanos
Old 02-27-2006, 03:53 PM
Good!
That jack will be fine.
Have another friend help you under the car.
PM sent.
Old 02-27-2006, 04:39 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Send a message via AIM to Stevebsy Send a message via Yahoo to Stevebsy
You should also put a quart in the TC before putting it on if you have a new TC. For a used one, it probably has enough in there to start with.
Thus quoted me Pat from Level 10.
Oh..and also, to reiterate about making sure it is seated all the way before installing, and to make sure it hasn't shifted during the installation, I like to turn the TC from the bottom while I am tightening the engine/trans together. If it stops turning freely, you have a problem, STOP!!! Or you will break the oil pump which will result in much swearing.
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway!
'20 Honda Ridgeline
Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here:
http://www.x35design.com
Old 02-27-2006, 08:57 PM
Again I really aprrecaite the info.
I'm sure I will run into some things but its good to know I have pros that have done it before on here.
1992 Subaru SVX
2000 Daewoo Lanos
Old 02-28-2006, 11:20 AM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
Send a message via Yahoo to SVX-FF
Good luck on the swap.
I used a strap to pull the front struts, with axels, away from the tranny. You can hook onto the rotors but do not apply to much pressure ot you will dent you fender. Strap holding rotors back
There is also a few other pics in my locker too, one on how to pull axel stubs out, along with a few little writeups.
Steve
92 SVX AWD 130,000 w/ rebuilt SVX 4.11
97 Audi A4 1.8T (Daily Driver)
03 Ford Expedition(hers)
SVXepidia SVX information warehouse
Are you in?
My Old Locker
A 4.11 Founding Father
"Tranny #6" I really need a manual
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
