I need front brakes
So a few years ago I bought a set of cadmium coated rear discs for my SVX, now the fronts need replaced and I need a set of fronts but I can't remember where I bought them from, aside from they were off ebay and came from Cananada. And ideas/recommendations?
Re: I need front brakes
Today it is probably not going to happen...
Cadmium oxide is a known carcinogen and inhaling fumes or vapors may be fatal. Cadmium compounds are considered carcinogenic. Better choice might be... PREMIUM CRYOGENICALLY-TREATED HIGH-CARBON CAST ROTORS FOR HEAVY DUTY & SEVERE DUTY APPLICATIONS; http://catalog.brakewarehouse.com/it...CRYO&weight=38 $256.99 for the pair FREE shipping Keith ![]() |
another alternative: http://www.r1concepts.com/subaru-svx-1994-4wd.htm
would you go slotted or drilled?
Thanks, Keith ![]() |
