Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Suspension
Old 10-27-2007, 02:26 PM
mbtoloczko's Avatar
sans SVX
reinforced front top mounts done
I finally finished up a couple pairs of reinforced front mounts for a few customers. Hoping this will keep the Konis from dimpling the hood and improve the stiffness of the mount which would improve handling. The second pair are made up with more filler because I'm expecting severe service conditions on that car. ;-)
Mychailo
Visit my locker
Old 10-27-2007, 04:18 PM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Mychailo:
How much for these guys. It is too late to avoid my first hood dimple, but I can avoid some more. Thanks.
Dan
____________________________________________
95 LS-i Red, 31,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2017 Subaru Forester XT, metallic dark gray, 29,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
2006 Subaru Outback LL Bean, 166,xxx sold
92 LSL Dark Teal, Smallcar Shift Kit - sold
Old 10-27-2007, 04:28 PM
Dessertrunner's Avatar
Mychailo I gather the second are for me? They come up real nice what the product you use on them?
Old 10-27-2007, 04:51 PM
mbtoloczko's Avatar
sans SVX
Hi Tony. Yes, that second set is yours. Just sent you an email to catch up on the other things we talked about. The filler is 3M fast curing polyurethane windshield sealant product number 08609. Supposedly, the Shore D durometer rating is 55-60. Its roughly the same durometer as the rubber in the mounts, but since it fills the gap, it will limit compression of the mount.
Dan, I'd be happy to make up a set for you, but its pretty easy to do yourself if you like. The key is to do it in several layers, letting the urethane cure in between applications. If you wanted to try an even stiffer filler material, discussion on the internet is that the PL construction urethane filler available at Home Depot / Lowes / etc has a Shore D of 90 (which is pretty rock hard). Best prices I've seen on Subaru parts is a place I purchase from in the Seattle area. 866-528-5282. Ask for Jason in parts.
Mychailo
Visit my locker
Old 10-28-2007, 09:15 AM
Mychailo:
Thanks. So the idea is that you lay in concentrically several thin layers of urethane filler in the existing gap of the stock top mounts, allowing each layer to harden between applications? If so, sounds very easy. Thanks.
Dan
Old 10-28-2007, 10:40 AM
mbtoloczko's Avatar
sans SVX
Yep, that's it. The set in the upper pic I did in three applications. The lower set was four applications. You'll want to clean the mold release compound off of the rubber beforehand. I taped off the bearings with masking tape prior to washing with dishsoap and the hottest tap water I could find. Nitrile or latex gloves are nice to wear when washing and smoothing the bead.
Mychailo
Visit my locker
Old 10-29-2007, 07:15 PM
wawazat??'s Avatar
Yeah, I'm still around
Mychailo,
I've been thinking of dropping the strut rod down with a spacer between the GC hat (aka top string retainer) and the bottom of the bearing in the strut mount. There is PLENTY of thread length to fully engage the nut and one could easily lower the adjustment nipple by at least 1/2" to 3/4" and still have everything fully tightened up.
Your thoughts?
Todd
Down to none
Old 10-29-2007, 07:18 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Originally Posted by wawazat?? View Post
Mychailo,
Your thoughts?
Todd
Don't use a copper spacer. It is a little weak but a 1/2 inch coupler is the perfect size!.
Old 10-29-2007, 08:13 PM
mbtoloczko's Avatar
sans SVX
Mychailo,
Your thoughts?
Todd
Definitely possible, but I think even 1/2" is too far. Here are the reasons:
1) The shaft threads may be long, but the engagement length for the bearing is only 0.58" long. The bearing itself is 0.48" tall, so there is a need for at least a 0.1" thick washer, but 1/2"-3/4" seems like too much. Maybe 1/4" thick should be ok.
2) Extending the shaft far down will cause the shaft to bottom out that many inches sooner. The GC upper retainer does block some shaft travel which is regained with a spacer. A smaller thickness spacer might be a good thing to bring back a little more travel. Maybe only for a long travel setup though.
Mychailo
Visit my locker
Old 10-30-2007, 06:32 AM
benebob's Avatar
We're at a 1/2 an inch with no adverse effects on the racer. Its been like that for 2 years. Just don't use copper. Did I say that yet
Old 06-23-2012, 01:39 AM
Tapani Tapani is offline
Re: reinforced front top mounts done
Bringing up an old thread....
Any long term experience with the reinforced top hats?
Just ordered new top hats (noise is still there, a small play can be felt by yanking a lifted wheel up and down with a crow bar) and with the Koni inserts I am thinking about doing this mod.... the adjusters are awefully close to the hood.
Tapani
Old 06-23-2012, 11:55 AM
I have a set of the rear ones that he made and they're great.
Old 06-23-2012, 01:23 PM
Do you have any photos of the rear ones?
Thanks,
Tapani
Old 06-23-2012, 04:20 PM
Thanks,
Tapani
No, but these are the same:
From this thread: http://www.subaru-svx.net/forum/showthread.php?t=58934
Old 07-09-2012, 04:23 AM
I "did" the new ones.... they are a very different design compared to the old ones to start with. There's app 10mm more clearance to the hood now :-).
One knocking sound is gone, but there's still something.... drives me nuts
Pls see photos.
Tapani
