Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 11-19-2016, 12:05 PM
clarkrp1027 clarkrp1027 is offline
Brembos
Hey guys, I am currently working on a project some may be interested in. Cadillac Brembo's on the front of the SVX with STi rotors. I should be acquiring a spare knuckle to start the bracket design in the next couple of weeks.
Check out a newer Facebook group for all things SVX, SVXNation
Or follow us on Instagram @svxnation
http://SVXNATION.COM
Old 11-20-2016, 04:57 AM
fasteract7's Avatar
fasteract7 fasteract7 is offline
Re: Brembos
Interesting project. Personally, if Carbotech made some X-8 front pads for my SVX I'd be happy. I believe according to a talk with them a while back, if you send them the pad backing plate they'll customize a set for a rather bodacious price tag.
Good luck with your mod projects..pictures in the future hopefully ?
Old 11-28-2016, 05:42 PM
Re: Brembos
Definitely pictures. If there is enough interest, I will be looking into having the brackets made to sell. With the caddy Brembo's a front set (caddy Brembo's, plain Jane sti rotors and pads) would only cost about 300 bucks plus the bracket. ~100 a caliper, and about 100 for centric brake rotors, GM CTS-V brake pads(same as STi), and sliders. So this could be done very cost effectively. Or you could go for the expensive pads and rotors as well, bringing total price up.
Old 12-17-2016, 02:41 PM
Re: Brembos
Here is what I currently have for a rear brake set up. Brackets will be easy, the hard part will be finding something that can use the whole rotor space while having enough room to make a bracket. It is an STI rotor paired with a z32 rear 2 pot calipers.
Front needs work. STI rotor and Cadillac Brembo's yrilds no room for a bracket. Will be buying a 355mm NISMO rotor that should be a perfect fit.
Old 01-16-2017, 05:09 PM
fasteract7's Avatar
Re: Brembos
Making anymore headway on this..will 17" rims allow enough room for your proposed set up?
Cheers
1992 Dark Teal LSL, 4.44 swap, B&M trans cooler, AFPR, RX8 rims, 235/40-18 tires, SS brake lines, Hawk HPS pads, Strongflex poly ft/rr swaybar bushings, starter solenoid mod.
Old 01-16-2017, 06:21 PM
Re: Brembos
We did a group buy of front caliper brackets on Facebook last year. Darin Entriken had them made IIRC.
Cheers
Not likely. Stock STi Brembos will attach to the stock SVX knuckles but our mounting lugs are spaced out farther than theirs. I tried it and my 17" STi BBS wheels wouldn't fit over the calipers. Had to throw on an 18" wheel to get clearance.
Old 01-26-2017, 12:30 PM
Re: Brembos
Cheers
Yea. 18s required. And I have no interest in 6 pots. Especially not at $600 for brackets.
I have tried several different photo sharing sites. None seem to work -.-
Old 01-26-2017, 06:09 PM
fasteract7's Avatar
Re: Brembos
What is the cost of the brackets based on,....... .?
