Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 10-09-2007, 12:20 AM
SVX Maxximus SVX Maxximus is offline
Jordan
Brake upgrade options
I understand that I need to upgrade my brakes whenever I increase power. I have replaced my front rotors with slotted ones from motorsport warehouse when my rotor was destroyed due to a brake pad "reed" not allerting me of it being worn out..oops. I know that these rotors will vent gasses better which will allow my rotors to accept a little more braking before warping?, but I would like to know of all of my options for replacing my brake setup that would not cost me my right arm, and would fit into 16" wheels. Would simply adding new brake lines in conjunction with my slotted rotors be enough?, or do I need to upgrade my calipers for more powerful ones too?
Old 10-09-2007, 03:39 PM
94SubieSVX's Avatar
94SubieSVX 94SubieSVX is offline
OOC for a while
Send a message via AIM to 94SubieSVX
OT is now a distributor for RaceConcepts brake setup, a steal if you ask me. look for the "race concepts business" thread
bLAh
Old 10-09-2007, 09:54 PM
Nevin's Avatar
Nevin Nevin is offline
I myself just did drilled/slotted rotors all around along with ceramic pads and stainless lines. THere is a DRAMATIC difference in stopping power. I'd say this is the way to go unless you have a track car.
Jesus is the remedy
2015 Expedition EL Ecoboost
Ebony Pearl '95 Subaru SVX LSi
Home of the Bontrager Works 22mm rear sway bar!!
Old 10-09-2007, 10:23 PM
It's Just Eric's Avatar
Missing in action
the d/s rotors extra venting helps prevent brake fade a bit more than "warped" rotors. The same conditions that would normally create any surface discontinuities will still apply to slotted rotors (So no 100mph to dead stops...you'll still screw up your brakes)
In addition to the d/s rotors and good pads, stainless lines help give the brakes stiffer feel. If you are looking for a CHEAP way to stiffen up the brakes, you can actually reinforce the rubber lines with zip ties, placed one after the other. Another cheap trick is to drill some holes in the dust shield to allow better heat venting
R.I.P Cool Signature.
Old 10-09-2007, 10:43 PM
Nevin's Avatar
Originally Posted by It's Just Eric View Post
If you are looking for a CHEAP way to stiffen up the brakes, you can actually reinforce the rubber lines with zip ties, placed one after the other...
That's true but...come on, they're $100. $25 a line that bolts right on and has stock mounting brackets is a steal to me.
Jesus is the remedy
Old 10-10-2007, 12:00 AM
If you got the juice for it, go for these: http://www.movit.de/rahmen/subaru.htm
Old 10-11-2007, 05:16 PM
Or you could do like me, and just let the road salt do the work of removing the dust shield (see attachment).
To the point of this thread though, get in touch with Tom (svxfiles). As it says in the other thread, he's now, or very soon to be, a distributor for RaceConcepts rotors, pads, and lines. A full kit (4 rotors, 4 sets of pads, 4 lines) will be $375+shipping.
