Muffler rattle sound
My black 95 has had a muffler rattle since I bought it years ago. Someone told me there is an inexpensive solution for this and the it occurs often.
Anyone know about rather this is common and is it easily fixed. |
where is the rattle coming from??
There are heat shields all over the exaust, its most likley one of them, just remove it ![]() Cheers, Jake
1992 Pearl / Black SVX removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads |
Holy ****.
I'll check for the heat shields. Thanks. |
If it happens only at specific RPM's go after the heat shields. My ford had two screws come loose and the heat shield rattled like a ***** from 1100-1300 RPM. Either remove them, or screw them back into place.
If it is not the heat shield it will be the centre "Hot Dog" (Oz Name). Just cut it out and put a pice of straight pipe in.
Tony
My vote goes to the heat shield. Both of mine rattle when I close the boot (and seemingly ALL of 'em on the silver rattlle at hight idle).
dcb |
Even if the bolts hang on, the mess that insulates the pipes wears out and eventually you get metal to metal noise.
The only ones I ever leave on are the ones welded to the manifold.
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts -
![]() [SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not ![]() Member #995 ![]() Catch you next at: ? Auto-X ? |
