Old 03-17-2013, 11:54 AM
05 LL bean 30r reviews?
I am thinking of picking up an 05 outback llbean. Upgrade from my current 00 outback which is slower and more boring than anything I have ever owned... ever... seriously this thing is slowly killing me by boring me to death. Anyone have any reviews on the 30r engines? I like the utility of outbacks but they are way too underpowered with a 4 banger.
Thanks in advance!
Old 03-17-2013, 12:03 PM
Re: 05 LL bean 30r reviews?
Just watch for timing chain clatter. They suffer from tensioner pad failures but other than that, great engines. It'spretty typical for them to have reoccurring catalyst efficiency codes so just something to keep in mind if you have emission testing and the CEL is on when you test drive it or if the OBD2 readiness isn't set.
Old 03-17-2013, 12:31 PM
My father-in-law had an 03 3.0 (not sure if EZ30 or EZ30R) LL Bean and it was great. Plenty of power. Not noticeably slower than the SVX.
Old 03-17-2013, 04:01 PM
Huskymaniac's Avatar
Uses the ignore feature
I have the 3.0 engine in the Tribeca. It does have decent power if you wind it out to high RPMs. The gas mileage is pretty crappy but that could be due more to the weight of the Tribeca. There is a lot of whine from the timing chain. It just clicked over to 108K with no major issues. It does consume coolant slowly over time though. Best I can tell, there is no oil to water or water to oil mixing going on. At worst, it is an external head gasket leak of coolant. All in all, I neither love or hate the car or the engine/tranny combo.
My favorite car still remains my old 1997 outback. Not for the fun but for the combination of utility and reliability. And that car supposedly had notoriously bad head gasket issues. At 160K and 15 years of driving there was never a hint of such problems.
Tony
Old 03-17-2013, 04:23 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
My favorite subarus are the 2.2 engine legacys, but Ive owned 2 1999 Outbacks 2.5 and so far so good with head gasket issues.
1995 POLO LSI 76K MILES SOLD
Old 03-17-2013, 05:36 PM
So... what does that have to do with the 30r engine?
Old 03-17-2013, 06:38 PM
subeman90's Avatar
Soobologist
I've heard the idler bearing for the fan belt goes bad too. Easy fix just something to maintain once every so often.
What ever happened to that Bimmer?
15 OBW premium w/eyesight
Old 03-18-2013, 04:32 AM
Got rid of the bimmer a while ago..
Old 03-18-2013, 05:58 AM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
I have a 2006 LL Bean Outback wagon. Great car. Did have a fan belt idler pulley failure. Had some kind of mysterious problem with the trans. After engine warmed up, sport mode light would start flashing and sometimes upshifts would be delayed into high revs, resulting in lurching shifts. After 3 visits to the shop and a couple of sensor replacements, problem has gone away. Car has vey good power. Does require premium gas. Mileage isn't very good. But, great car for trips, lots of room for carrying stuff, very comfortable, especially for tall people, very good in the snow. Did I say it had good power? One of the best cars I've ever had. Got it January 2008 with about 30,000 miles. Now has over 90,000. Car is holding up very well.
____________________________________________
95 LS-i Red, 31,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2017 Subaru Forester XT, metallic dark gray, 29,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
2006 Subaru Outback LL Bean, 166,xxx sold
92 LSL Dark Teal, Smallcar Shift Kit - sold
Old 03-18-2013, 07:36 AM
Great! Thanks dan. I wasnt sure what gen yours was good to hear 1st hand reviews.. i look forward to checking this one out
