Go Back   The Subaru SVX World Network > SVX Main Forums > Technical Q & A > Chris's SVX Shop
Old 09-06-2007, 09:32 AM
Nforcer Nforcer is offline
You have been Nforced!
cruise control
the cruise control doesn't work in my 92 ls-l. it hasn't worked since i've owned the car. i can't find a FAQ on this subject, but if there is one, can you point me in the right direction?
Old 09-06-2007, 10:16 AM
svx_commuter's Avatar
I don't know where you should look. If your speedo is working then it may be a simple as the vaccum hose form the intake manifold to the CruiseControlUnit is not attached or leaking. Other than that easy fix does the light come on for the Cruise Control when the button is pushed? If the light doesn't come on doe sthe button stay in?
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 09-06-2007, 07:52 PM
JaySVX's Avatar
JaySVX JaySVX is offline
Press the cruise control button on the dash. If it lights up, that part works, and that's good. If not, check fuses. If it lights up, go under the hood, and look towards the rear of the engine. There's a black cylinder type thing with vacuum hoses in each side, with the sides facing the side of the car. thats the cruise control actuator. Make sure the vacuum lines are connected properly, and that the other ends of them are connected. If that doesn't work, check out http://serial.cc/pdfs/CRUISE_CONTROL_SYSTEM.pdf for a detailed layout of the system, specs, and config. That should answer your questions if the other two suggestions don't' work.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 09-07-2007, 12:10 AM
cruise control
the button doesn't stay in at all. but does light up when i hold it in.
Old 09-07-2007, 05:35 AM
Okay the button does not stay in. sorry about that.
I just went outside and pushed mine a few times.
There is clicking noise that comes from the center console area when it turns on and off.
This must be a relay clicking.
If you don't hear the relays in the console then something else is not working.
I do rememeber that sometimes the light didn't stay on and and I'd have to push the button a few times. Try a rapid fire sequence of pushes and see if it sticks.
If you do hear the relays try to hold the botton in and see if the cruise will work.
Old 09-07-2007, 05:40 AM
dcarrb dcarrb is offline
So you're saying the light goes off when you release the button? If so, try repeatedly to get it to stay on. For whatever reason, mine takes several attempts to engage when it goes unused for awhile, and I believe this isn't unusual.
dcb
Old 09-07-2007, 05:42 AM
JaySVX's Avatar
Give me an hour and I'll go take a video of normal operation of what it's supposed to do on my next cigarette break.
Old 09-07-2007, 06:09 AM
Start the car, and REPEATEDLY push the button on.(and off)
Like 100 times.
This will clean the contacts in the gosh darned switch!
Old 09-07-2007, 09:05 AM
JaySVX's Avatar
Normal Operation of the cruise control button:
http://simplepic.net/displayimage.ph...up&cat=0&pos=0
Old 09-07-2007, 07:32 PM
cruise control
i've tried your link 4 times now. nothing comes up.
Old 09-07-2007, 09:41 PM
JaySVX's Avatar
It's encoded in avi. You may need codecs for it.
Old 09-08-2007, 09:36 AM
Have you tried pushing the button 100 times?
Old 09-08-2007, 09:42 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Send a message via AIM to Ricochet Send a message via MSN to Ricochet Send a message via Yahoo to Ricochet
When I bought my car the cruise button was funny. I pushed it 99 times and it still wouldn't work. That 100th push fixed it right up though.
Brian
Old 09-08-2007, 09:55 AM
SEE!
Thanks Brian.
Old 09-10-2007, 12:35 PM
cruise control
well, after 100 or so hits to the button, i've noticed that it still doesn't light up at all.
[IMG] code is Off
