Old 08-25-2011, 06:14 PM
shark_22 shark_22 is offline
chek engine-38-
hi, i have a 5 speed transmition in my car. since a do the swap, i have the cel 38
38-
Engine torque control
Wiring harness between ECU and TCU is in short circuit
i have to tap in the wiring to *bypass the tcu?
somebody have done this swap?
thanks you
Old 08-25-2011, 06:27 PM
Re: chek engine-38-
Unplug the TCU. You don't have to do anything else.
Old 08-25-2011, 06:46 PM
Re: chek engine-38-
i done that during the swap, but do you know if i have to tap in the ecu a wire to remove the cel?
Old 08-25-2011, 07:09 PM
radarwhiz's Avatar
Fairmont State University
Re: chek engine-38-
38-
thanks you
I never had that problem with my swap so I didn't bother doing it but this is from Huck369's write-up:
Elazar
'08 ML550 daily driver
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 08-25-2011, 07:48 PM
Re: chek engine-38-
ok thanks for the information, im gonna try this!
Old 08-25-2011, 07:59 PM
Re: chek engine-38-
And this has to be done Y. What if it is not done ? What will happen ? I have to check and see if mine was done.
Old 08-25-2011, 09:05 PM
Re: chek engine-38-
This does not need to be done. It is something leftover from the early days of 5mt swaps that turned out not to be necessary.
Just remove/unplug the TCU (and sell it to some fool with an auto).
OP: what year is your car? Must be OBD 1 since the code is a small number like 38. A 96 or 97 cannot have an MT without throwing a CEL with the stock ECU.
Old 08-26-2011, 01:45 PM
Re: chek engine-38-
1904 Svx..... dumb fingers 1994
Old 08-26-2011, 02:14 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: chek engine-38-
1904 Svx.....
That's the one that went head-to-head with Henry's Model B! 24hp sure packs a wallop!
Old 08-26-2011, 06:54 PM
longassname's Avatar
Just some dude.
Significant Technical Input
Re: chek engine-38-
I'll give credit towards a Stage1Av1 for an AWD SVX TCU.
Old 08-26-2011, 08:57 PM
Re: chek engine-38-
Hmm what would two of them get me?
Old 08-27-2011, 07:23 AM
Just some dude.
Re: chek engine-38-
$158 credit
Old 08-27-2011, 08:23 AM
Re: chek engine-38-
I'll let you know. Any chance you could hook me up with some of the fancy aluminum bearings you used to sell?
