Power Steering System - Which Fluid???
I did some work on my PS system.. Replaced old fluid with POWER STEERING FLUID.. . SOme here say it's OK. Some say change immediately!
![]() ATF? or Power Steering Fluid? .. or BOTH OK ? Whaddayatink??? ![]() Thanks, Jim ![]()
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) ![]() ![]() Last edited by James Scott; 03-09-2011 at 06:00 PM. |
Re: Power Steering System - Which Fluid???
ATF... no question. PS fluid will cause problems.
Ich bin ein SVXer wieder My Rides: Red 1996 SVX LSi (Saffron) 2007 Yamaha FJR1300 (Kaitlin) Previously owned; green '95 L AWD (sold), black/pearlie '94 LSi (too many problems), Polo Green '96 SVX LSi (apparently notThe end of an era) Member #2 in the Yahoo! club, been here since the beta-testing days. In dire need of a cheaper hobby. |
It clearly says on the top of the PS Pump lid to use only DEXRON ATF.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
Look at BMW for an example of "wrong fluid"; it's widely felt that one of the biggest problems with the recent High Pressure Fuel Pump debacle (referred to as HPFP in the community) is because HPFP's are primarily designed for use in diesel engines. Diesel fuel lubricates seals, but gasoline dries them out. Although there's been no confirmation, the HPFP problem is widely regarded to be because of this.
Since it only takes about a quart of ATF to fill the system, I would replace what you have in there with Dexron.
The turkey baster method works just fine if you dont want to jack up the car. (Less work, more fluid changes.) BTW, I have been REALLY pleased with BG Products ATF! ![]()
