Old 01-02-2012, 01:32 PM
Gamesy's Avatar
Gamesy Gamesy is offline
idler tensioner pulley
I called the local subaru dealership for a idler tensioner pulley and he said it was gonna cost $151 is it me or is that a little too high for a pulley?
also what other cars does that one share with?
subaruparts.com lists it as $40 for it.
btw is there still that discount code going on?
Old 01-03-2012, 04:40 AM
dcarrb dcarrb is offline
Re: idler tensioner pulley
Which pulley are you talking about?
I've recently purchased two AC belt idler pulleys; cost was $50-something each, shipped from subaruparts.com. They were in stock so I'd guess there are multiple applications.
dcb
Old 01-03-2012, 06:31 AM
The idler tensioner pulley for the A/C system is located on the bracket on the front of the engine on the right side. The PN is 73015PA000 /Pulley Ay / $51.26
The power steering pulley which had the tension screw adjustment for the P/S and alternator is 34413PA001 /Idle Pully Assy /$43.55
Old 01-03-2012, 11:20 AM
Gamesy's Avatar
The idler tensioner pulley for the A/C system is located on the bracket on the front of the engine on the right side. The PN is 3015PA000 /Pulley Ay / $46.52
The power steering pulley which had the tension screw adjustment for the P/S and alternator is 34413PA001 /Idle Pully Assy /$41.90
ya i called back the guy was thinking timing belt.... dumbass, unfortunately its still cheaper to get it locally then to get it from subaru parts.com just cause of the shipping and possible customs
Gamesy's Avatar
do any other subys share the same one?
Old 01-03-2012, 11:45 AM
Is the pulley scrap or just the bearing? If it's just the bearing you can knock it out with a socket (remove the snap ring first), bring it to a bearing store and get a new one for like $10. That's what I did! Took less time than waiting to Subaru to get a pulley in too.
Old 01-03-2012, 12:16 PM
Gamesy's Avatar
we talking about the same pulley here?
mine apparently is a balanced pulley, i tried knocking it out but i cant, there's actually a plate on it thats riveted and that will need to come off to get the bearing out
Old 01-03-2012, 12:34 PM
Ah, maybe not... Can't remember if it was the A/C idler or the alternator and P/S belt.
Old 01-04-2012, 03:33 PM
aust92pearl aust92pearl is offline
my dad drilled out those rivets and replaced the bearing on that pulley in my pearlie #1 he used some steel rod and mushroomed it over to replace the rivets
the bearing in that was almost seized and he had a correct size bearing in his inventory (hes a welder/fabricator/diesel mech at a boat repair slipway
cant actually remember the bearing size but i think its fairly common
Old 04-11-2012, 02:47 PM
92 SVX 92 SVX is offline
Hey does anyone know if a wrx has the same
I am looking for something local quickly I know a few wrx and sti guys that may have one.
