Old 02-12-2007, 04:10 PM
pearlm30's Avatar
pearlm30 pearlm30 is offline
Help! Rear Trany mount Bolts Striped...
I was trying to locate the squeaky sound from the rear part of trany on my 94 FWD. Turned out the 2 bolts that bolt the trany mount to the rear trany case cover striped the holes inside. Who ever did the last trany removal screwed it up!!!
My question are
1)Can I repair the thread? I hear about so call Heli-Coil, but dont really know how to use it? What about just JB weld it? Would it hold?
2)Or I need to just replace the tail housing cover plate where the trany mount was bolted to? Its 94 FWD, so it didnt have the drive shaft coming out of it.
3)Is this trany same as Legacy's? Can I swap the cover plate with a FWD legacy?
If not, I will post a seprate post in wanted forum
Thanks for the help!
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 02-12-2007, 05:08 PM
davew833 davew833 is offline
Easiest thing to do might be to tap the holes (re-thread them slightly larger) if there's enough material around the holes in the cover, and not too much distortion of the holes, then use bigger bolts. You might have to drill out the holes on your tranny mount, too.
Helicoil is not much harder to use, and would work as well. Basically, you're replacing the destroyed threads with a coil of harder, stronger metal threads, which twists in with a special tool included in the kit.
JB Weld might hold for a while, but there's a lot of torque there and I'm guessing you'd have to redo it eventually.
There's a '94 FWD SVX tranny sitting loose in the U-pull yard near me. I might be able to get you a cover if all else fails, but I don't have any idea what it would cost right now.
davew833@yahoo.com
Former 6-time SVX owner
Old 02-12-2007, 05:23 PM
My question are
1)Can I repair the thread? YES
They come with instructions
What about just JB weld it? I would not.
Would it hold????
2)Or I need to just replace the tail housing cover plate where the trany mount was bolted to? That would be best.
3)Is this trany same as Legacy's? Very close.
Can I swap the cover plate with a FWD legacy?Yes!
BTW, I have that plate.
