Old 07-21-2006, 08:55 PM
subster subster is offline
TC Bolts won't come off.
I've used all of my tricks. PB blaster, patience, tapping them with a hammer gently, whispering sweet nothings to them...
Then, I lost patience, said screw it and stripped one with a vice-grip.
Crud.
Any suggestions??
Can I take the tranny off with out removing those bolts?
Thanks
Old 07-21-2006, 10:04 PM
Manarius's Avatar
Manarius Manarius is offline
Breaker bar? I find one of those to be immensely useful on really tight nuts.
-Jason
-Obi Wan Kenobi
Old 07-21-2006, 11:24 PM
use a small die grinder and go at it. I had one hang up on me and it took me 20 minutes with a die grinder and it came right out. Just be careful you do not dig into the flexplate and be sure you buy new bolts
TOm
Old 07-22-2006, 09:27 AM
TOm
It's not a matter of torque, it's a matter of gripping those bolts. The heads on them are very shallow and the tool slips off. A 12mm wrench seems a bit too big and an 11mm is too small. I should have checked it with a standard size.
So I can just grind the heads off of the bolts that don't come off? I'll be carefull with the flexplate.
Thanks alot,
Noah
Old 07-22-2006, 01:23 PM
NeedForSpeed NeedForSpeed is offline
Agreed with Subster, it's a matter of gripping the bolts.
And young Tom's solution may be your only choice. Bolts must be removed.
Svxfiles likes to remove the alternator, and go in with a six point socket and several long extentions. I don't believe this has ever failed him. I've done it both ways, with luck so far.
If you are careful, you may get enough bite on the bolt using svxfiles method, even after the vise-grip mess.
Good luck, let us know what happened.
Thanks alot,
Noah
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 07-22-2006, 03:40 PM
Thanks for the advice. Do you know what size they are? I'm at work now. I bet they are standard, not metric.
I'm willing to take the alternator off. I didn't realize it was an option.
Old 07-22-2006, 07:02 PM
fishtail fishtail is offline
Smile
In reply to the problem your having with torque convertor bolts. Just changed my transmission I had one bolt that did not want to come out. Got under the car with an air chizle with a pointed bit. Got on the edge of the flange and rotated the bolt out. Be sure to put in new bolts with locktite. Fishtail
Old 07-22-2006, 07:46 PM
They are 12mm, I use a six point 3/8" drive socket, and a 22" long extention, snaked under the intake manifold.
I hope it goes better for you.
Old 07-22-2006, 08:00 PM
demonsvx's Avatar
demonsvx demonsvx is offline
building more AK47's
I used a long extension taped to the 12mm socket under the manifold hooked up to a impact wrench on its LOWEST setting went slow and easy and they came right out.
1992 SVX LSL Ex wifey has it now pending self destruction 2001 Legacy mods to come 1992 Subaru Legacy 2.2 214k Boob wheels CANT KILL IT
Old 07-22-2006, 09:53 PM
if you remove the TB you can just use a 12mm 6point sockt on a ratchet...no extensions needed... this proves to be the best way to do it as there is no need to buy extensions and less chance you will round one off as there is less torque applied to remove it... Just an opinion
Old 07-22-2006, 10:00 PM
SVXelerator SVXelerator is offline
Frequent User
Sears 12mm racheting box end wrench .... don't even need to take the TB off...
Maximum acceleration, maximum lateral g-force...it can be done, it just takes time and $$$
Old 07-22-2006, 10:15 PM
Speedklix's Avatar
Speedklix Speedklix is offline
Locker Link Solution
For some reason it doesn't seem like that would work. Isn't the bolt in like half an inch? Its been a while, so I could be wrong But the TB is true, I never removed my TB for the swap, there really was no need.
I held the prybar in one hand to steady the crank and just a ratchet and 12mm to break the bolt free standing on the pass side. I then used a 3 inch extension (with no ratchet) to turn the bolt quickly and remove it. turn the crank to next bolt and repeat. If I knew I didn't need that flexplate again, I'd probably just take a wizz wheel underneath and cut off the heads where you would install the stopper. The die grinder is a good idea, though if you have the patience and want to keep the flexplate.
-Mike
ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC]
In progess: track down mystery noise <-identified, paint the new dash, get better pic
Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165
Member #995 | My Locker | My New Locker
Catch you next at: ? Auto-X ?
Old 07-22-2006, 11:18 PM
Wow, great response! Thanks for all the advice. I'll be back at it on Monday. I have the throttle body off already so that's helpful in terms of access to the bolts. I'll let you all know how it went.
I didn't realize how many people have done the swap! That's cool.
Old 07-23-2006, 03:49 AM
Or how many times weve done it.
Old 07-23-2006, 09:50 AM
Or had to re-do it
