Zoom lowering springs with Koni's (1 of 2)
So just about finished fitting the whole set, will post photos (before and after ride height) when everything is back in the car - as the interior should help settle things down a bit.
Koni's are set soft, which are actually a lot firmer than OEM with the 2-3" lowering Zoom springs that I bought from www.jauce.com
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 05-02-2017 at 05:06 PM. |
Re: Zoom lowering springs with Koni's (2 of 2)
Part 2 ...The dust seals (2 off) are fitted to the strut tower top cover plastic pieces, and also (4 off) where the Koni's are mounted at the lower area of the struts - I made a cover plate that is welded flush with the outside lower flange area then turned a hole that fits the same dust seals, that way no water/mud can get into the lower mounting Koni bolt - so no chance or rust - see posting #5 for photo.
Will take photos of this tomorrow.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 05-02-2017 at 05:04 PM. Reason: added description. |
Re: Zoom lowering springs with Koni's (1 of 2)
Very nicely done......me likey
I can't believe how clean your car is underneath... Looks like it came off the dealer lot last week.
Thanks - the towers have been bead blasted and powder coated, all nuts/bolts/rubber pieces are new.
You can now see the bottom of the strut tower with new welded cover plate together with the dust seal fitted - this gives you just enough clearance to use a thin walled socked to torque up the lower mounting bolts for the Koni's.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 09-12-2018 at 06:18 AM. |
one of the whole car ... comments welcome guys and gals
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 05-04-2017 at 04:46 PM. |
Looks very nice.
Which Koni did you use?
I used the USA available inserts from Dayle at -
http://svx-motorsport-accessories.st...trutsrear.html
