Driver's Side Door Lock is Stiff
So all of a sudden my drivers side door lock is hard to turn. It catches if you jiggle the key a bit, but it feels stiff when it does turn. Also the key fob doesn't lock or unlock anymore, (nor does it make the beeps). It may just need a new battery but I'm betting the 2 issues are related. It has ben sitting for about a 5 days but worked fine before.
I puffed some graphite in the key hole and it improved, but only a little. Right now it is usable but definitely a pain to lock. Any suggestions?
Re: Driver's Side Door Lock is Stiff
I've had success with disassembling and soaking the tumbler in vinegar overnight followed by graphite.
try pulling the door lock fuse out and putting it back in. I've had success with that before when the door locks were not working.
I'll try that tomorrow. Thanks
I am guessing that you take the tumbler out by removing the interior door panel, is that right?
Mine were stiff when I got the car last year. A little bit of WD-40 later and my locks were in fine shape.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
Quickest way to do it is to take a can of penetrating oil, attach the little plastic tube to the nozzle, stick it into your lock, and spray. Insert key, turn back and forth a whole bunch of times. That should loosen it up pretty well.
I'll give that a try, thanks.
Happiness is an easy fix.
Just a few squirts of penetrating oil and good as new.
