Re: If you were going to pull a 195,000-mile engine...
How much longer before you pull the engine out? Something you could do is send in a used oil sample to Blackstone Labs to get an idea of how the bearings are feeling. When you pull the heads off you'll be able to tell what the cylinders look like. Honestly if everything looks good at that point I'd be on the side of leaving it alone and letting it roll on.
92 Ebony Mica LS-L " A Rolling Restoration": 223,250 KM - Sleeping
