Re: Pistons,Rods,Cams for FI Engine
Originally Posted by SomethingElse
I went to rallispec.com and couldn't find the rods.
Will i be able to run my 12psi pully with that? I think I have meth injection..havent done much under the hood yet.
I emailed them and asked if they had any and he hooked me up. Try to get some eagle ones first, it's the only place where I "cheaped out". I think you should definitely be able to run 12 psi with that, that's around what I'm aiming for.
'94 Laguna Blue LSi ~159k .......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project
'97 Ebony LSi ~137k #036 .......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod
