Originally Posted by svxcess
Maybe stainless steel lines offer more protection. Aging rubber brake lines may be more susceptible. Would worn rear struts add to the possibility?I think OT ought to comment here with more information on the failure. Seems like the mounting bolts were a different size, not sure. I thought he said that the top bolt on the anti-sway bar link on the passenger side had contacted the banjo bolt to the caliper, causing a brake fluid loss..
OK, It was the top bolt that contacted the banjo bolt at the brake line on the passenger side caliper.
It did not break the bolt, but nuged it enough for a fluid loss, causing the pedal to go to all the way to the floor, slowly.
Perhaps MY Nevin bar is wider than the rest?
When I get the chance to work on my Pearlie, I will measure the width.
Evan with the adjustable links reinstalled and at their shortest adjustment, there is only about 1/4" of clearance between the top bolt and the banjo bolt.
On the drivers side its about 1/2".
Huck, I really dont want to bend a hardened bar.
A set of 150-155mm links would fix it on my Pearlie.
John, the suspension is stock and the springs and struts are in good shape.
So sagging is not an issue with it.
