Re: Driving Issues
Coolant temp sensor (CTS) is frequently associated with starting problems, and fairly easy to replace.
For the TPS, if it just can't be adjusted to work normally, then you should try a new one altogether (or a known good used one). I would also suspect the wiring where the QC was. I imagine that if the TPS wiring is messed up just right, it could have some symptoms like a bad TPS.
'94 Laguna Blue LSi ~159k .......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project
'97 Ebony LSi ~137k #036 .......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod
