Re: Post engine swap troubles
I should have 2 sets of good heads actually. I have another spare motor. The engine that came out of the car had a water/oil headgasket leak (no smoke out of the exhaust or anything) that led to enough water in the oil to blow the motor. I felt some pieces of metal in the oil pan with my finger through the drain plug. So most likely bottom end damage like a spun bearing. Probably no top-end damage.
I guess I should get started pulling some heads to rebuild just in case. Well there goes any mystery to my weekend plans...
'94 Laguna Blue LSi ~159k .......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project
'97 Ebony LSi ~137k #036 .......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod
