Re: auto seat belt stuck
If you unplug the seatbelt motor on that side ( The plug is near where the hole to crank it back is, but I forget exactly where), then it won't go forward anymore. Also if you unplug the seatbelt controller which resides in the ceiling of the trunk.
I also vaguely remember some way of hooking up the rear window switch to the seatbelt motor to control it manually, but you'd have to search for the thread. Could be a way to test if the motor or controller is bad.
'94 Laguna Blue LSi ~159k .......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project
'97 Ebony LSi ~137k #036 .......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod
