Motor back in, crank like it has no compression.
Just replaced the head gaskets in the engine, re-installed, and now it just whirls away without any compression noises. If I crank it by hand I can feel some compression. There is tons of fuel getting in, there is spark, we pulled the right valve cover to check the cam timing (the single dot on one between the two dots on the other), the cams are in the right place, the valves on the right are opening and closing nicely...
Thoughts? I'd rather not have to pull the motor back out.
92 Ebony Mica LS-L " A Rolling Restoration": 223,250 KM - Sleeping
