![Old](images/statusicon/post_old.gif)
04-24-2008, 06:26 PM
![Crazy_pilot's Avatar](image.php?u=4866&dateline=1173731606) |
The short version? Remove the entire back end of the car. Diff, axles, suspension links, subframe, the works.
It may be possible to get at the lines you need to fix through the access panel under the rear seat.
If you do end up dropping the tank, check the brake lines that are back there. It may be good preventative maintenance to replace them while they're accessible.
92 Ebony Mica LS-L " A Rolling Restoration": 223,250 KM - Sleeping
