AWD not working......
I have a '95 L with AWD and the AWD is not working. Just last spring, early in the spring, I replaced the seal on the back of the trans because it was leaking badly. Not that this should affect the spinning of the driveshaft so long as it is in. It obviously is. I get PLENTY of FWD power but nothing at the rear wheels and power never transfers AT ALL! I was told to make sure that the FWD fuse had nothing in it and there was not one in there. I did also have my head gaskets done but that shouldn't affect anything unless something was left unplugged while pulling the motor.
Any thoughts? |
Re: AWD not working......
Has anyone noticed that the AWD fails on the 95's more than any other year? There must have been a bad run of transmissions. It's almost always a sheared off drum from what I understand.
Yeah a 6 speed swap cures half the problem of the SVX. I think it is the way to go for future projects.
I wish that was my problem. :(
