P.S. are the timing rings on the back of the sprocket included with the new sprocket from subaruparts? it looks like it from the diagram but i want to be sure. thanks, Jason |
If you're referring to the washer like ring behind the sprocket yes, it should be included.
I was surprised today when www.subaru.com only wanted $32.00 plus $8.00 shipping for it! I actually expected more, heck they want $160.00 for the crank pulley! :eek:
Good job, Jason! |
You may want to check that hole in the crank and see if it is deep enough to accept the full length of the BOLT. See how far in that bolt will go without the pulley in place.
How are you going to hold the crank to torque the bolt? I use a large strap wrench on the pulley. |
yes the bolt will go all the way in without the pulley on.:) |
-Chike |
1) Remove your spare tire and tools at the strip to lower weight. 2) Don't run with a full tank of gas (1/2 tank or lower). 3) When you get to the starting line, brake torque to 2,000 rpms and on the 3rd amber floor the gas. You won't red light and you should cut a 2.2 sec 60ft time. 4) Don't let off on the gas until you're sure you've completely passed the 1/4 mile timing lights! Good luck! -Chike |
got it;) don't worry, i've been racing for a long time now. i'm gonna experiment with launches and see what i find out. really want to see what the "secret" launch produces for times cause it really does feel faster that way when you do it right. the "secret" i'm talking about it is hitting the throttle to part throttle and engaging power mode and then increasing the throttle with rpm. i did it once and it turned into super svx!:D it's hard to repeat though. right now though i'm just hoping to get it running and have enough money to actually do the 18th. we'll see how it goes.:) |
oops i didnt see this thread from a long time. Great you made things straighten up even you were frustrated in between. Happy to see your baby being fully loaded and rocking again on the streets. enjoy, -Pavan. |
