SVXBot
Old 07-19-2021, 06:31 AM
SVX_MY_BABY's Avatar
Re: Lsvx-t
What type of shocks have you got in there?
Peter
ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels.
Old 07-19-2021, 07:17 AM
Re: Lsvx-t
Gecko "race" coilovers. We'll see how well they hold up. If they are miserable, I may just make custom control arms to utilize STI hubs since my brake kits is meant for them anyway. More on the brakes next month as I won't see them for a while
Old 07-19-2021, 11:13 AM
Re: Lsvx-t
Will you need to cut a hole in the hood? It look like it might just fit.
Originally Posted by TomsSVX View Post
Most of my electrical work I can do is sorted. So I have begun final assembly. I do need to get my hot pipes wrapped but that's not too big of a deal.
No SVX at the moment
Old 07-19-2021, 11:47 AM
Re: Lsvx-t
Hood will definitely require some modification
Old 07-19-2021, 06:34 PM
oab_au oab_au is offline
Re: Lsvx-t
It would look more interesting without one Tom.
One Arm Bloke.
Tell it like it is!
Old 07-22-2021, 06:20 AM
Re: Lsvx-t
I wish I could but the room is simply not there. Hopefully I can find a creative way to make it look like it's supposed to be there
Old 07-27-2021, 04:37 PM
Re: Lsvx-t
So got really close to starting it for the first time today. Unfortunately I will not be able to use the Subaru throttle pedal I wanted to as the sensor values are outside of the acceptable parameters for the Holley ecu. Since it's dbw the engine will not start without a properly calibrated tps. I have the correct pedal coming for tomorrow. I will have to make another adapter plate for the new pedal. I did hotwire my fuel pump and adjust the fuel pressure regulator and ensure the preliminary wiring is good. Tomorrow I will work on wiring in my fans and relays and find a way to use the vss from the trans to work with the ECU inputs. I will try and put up a first start video if I get the pedal early enough to do it without the neighbors calling the fuz. It's really coming together!
Old Yesterday, 04:29 AM
Re: Lsvx-t
grrrrrr! Neighbors.
Old Yesterday, 04:26 PM
Re: Lsvx-t
We'll it was short lived but it's alive!!! https://youtu.be/uPV1dAc5-Ls
Long story short I couldn't get it to restart again lol. Talking to Holley tech support and found the aftermarket throttle body was causing a tps error. Whenever this happens it cuts fuel. I plopped a spare truck throttle body on it and fired up without issue. So now I get to shop for a real deal tb. Not really a big deal since this one came with the intake manifold but still a bummer.
Old Yesterday, 07:23 PM
irox irox is offline
Re: Lsvx-t
WOW! Looks great, sounds great!
Congrats on the first start, and thanks for letting us follow you journey.
Cheers!
Ian.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
2001-2015 SVX World Network
