Old 12-11-2002, 08:28 AM
Shocker33 Shocker33 is offline
u joints?!?
Had a u joint go out yesterday, the guy at the shop tells me that it can not be replaced in an svx driveshaft and that i'll have to buy a new driveshaft (800 bones). He says the driveshaft is fine but they have no way of getting the bad u-joint out. Any body have any experience with this. If i do have to buy a driveshaft, I can buy a colemann alum. one for a lot less than 800 bucks.
Old 12-11-2002, 10:07 AM
cbx-man cbx-man is offline
subaruparts.com sells the whole "propeller shaft" for ONLY $444.49
http://www.subaruparts.com/diag/?mod...category=199-A
cbx-man
'92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter
'92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft
'80 Honda CBX in-line 24 valve 6 cylinder
Old 12-11-2002, 10:28 AM
There is this listing which may be worth checking out.
http://www.rockforddriveline.com/Staked%20Ujoints.PDF
And this:
"What does "Staked-In" U-Joint mean....
...until now, it meant as much as a $1,000 complete driveshaft replacement!
Most standard universal joints have either an internal snap rings that sits inside the ears of a yoke or flange and sits into a groove that has been cut into the universal joint cup. The other design is external snap rings they sit in grooves that have been machined inside the ears of the yokes and flanges.
Staked-In references the manner of how the universal joints are held into the yokes & flanges because the metal of the yoke & flange is acually forced over the edges of the univesal joint cap to hold it in position. This peened over material is removed and a U-Joint with internal snap rings is used to service the driveshaft - another engineering challenge solved by Rockford Driveline Products. "
cbx-man
Old 12-12-2002, 10:59 AM
rockford Driveline
Got the Rockford Driveline peice on the way. I'll write back and tell you all if how it works. Could be an easy solution to a $400+ fix.
over and out
nick
Old 12-17-2002, 10:56 AM
Re: rockford Driveline
over and out
nick
For curiosity, what is the cost for parts? Labor cost being another issue itself... unless it is a DIY project.
Matt K.
cbx-man
Old 12-17-2002, 01:44 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Re: u joints?!?
That means they aren't equipped to do it and they don't want to give you a referral. I heard the same line from my dealer years ago and I took it to a driveshaft place (A1 Driveshaft in Milwaukee) and the fixed it up for about $100.
Check in your phone book under Heavy Equipment drivetrain repair. They usually will fix anything if you are polite to them.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 12-18-2002, 03:32 PM
cost...
The u-joint cost 29 bucks with shipping. I did the work myself since I have a press and just about everything else a well prepared racer would need. I don't suggest doing this with out a press, the suby joints were a pain in the arse to get out.
Old 04-02-2003, 10:53 AM
mbtoloczko's Avatar
sans SVX
Re: cost...
So how well do the replacement u-joints work? Is there any freeplay?
Mychailo
Visit my locker
