here is a copy as if looking through the pcb - easier to trace from component side.
Re: Help, No Power! (power mode, that is)
Ground to dim all the lights. From the Time Control unit. Positive. Negitive. Harvey.
what are the transistor numbers (upright TO92 type - round with flat side)
Suspect that the main power diode - big round one is there for reverse voltage protection (it'll be something like a MR751). Could you by any chance have swapped over the + / - wires at any stage (either at the connector or at the other end of the wires?). Wil know more when I get the transistor numbers. Last edited by SURTEESS; 03-07-2012 at 07:01 PM. |
C945 P214A The one closer to the big green transistor reads: C1213 AKC 1K3 The big diode says S5225 1K on it. The way this board attaches to the instrument cluster makes it impossible to reverse the connections. I suppose it's possible that when someone installed the remote starter that some wires got crossed somewhere. I was real careful to make sure that I completely insulated the stripped wires when I removed it. They had not actually cut any wires when it was installed, just stripped a small section and soldered onto the wire. I used shrink wrap and electrical tape when I took it out. Although, I don't think that any of the wires used in the remote starter were directly connected to this. I'll check that diode tomorrow after work.
Glen SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery 2002 F550 74K SOLD - 2000 F450 215K 1987 BMW 535i 209K 1999 Yamaha SRX 700 |
Turns out that is a T S5225 zener diode. I couldn't read all of it until I removed it from the board. I tested it with my DMM and it tests bad! There is no resistance either direction. So I'm hoping that's the only problem.
Now I just have to find a replacement...
Glen SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery 2002 F550 74K SOLD - 2000 F450 215K 1987 BMW 535i 209K 1999 Yamaha SRX 700 Last edited by SVX8588; 03-08-2012 at 06:35 PM. |
I think I found a replacement:
http://www.mouser.com/ProductDetail/...WcTtboKYmJ0%3d Here's another close up of the diode. Can anyone confirm that this will work for me? Thanks
No that is only 3V 0.5 watt. You need a 7.2V 10 watt.
It has to dissapate the voltage that is dropped from dimming the lights. Harvey.
These are closer.
IN2970 6.8v 10watt IN2973B 9.1 10Watt The voltage difference will only change the amount of the dimming. Harvey.
Also, you guys are awesome. This is how more of us should go about fixing failed modules and electrical bits. I would have just replaced the whole board or gauge cluster. I am somewhat competent when it comes to soldering things, but my electrical components knowledge is limited. Next time something electrical fails, I'll see if it can be fixed instead of tossing it.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ............Photo album
FTFY ......
#28
search for the 2970 and I found a data sheet that shows it as a huge bolt-type thing (I guess it's called stud-mount). The 2973 looks similar. Are you sure those are the right ones?There are several good sized resistors on the board, so maybe it's designed so some of those dissipate some of the energy? ![]() Besides they cost $19 a piece and the minimum order from DigiKey is 175
#29
ok - here is "rough" circuit diagram. I am still of the opinion that the supply rails have been swapped over - & the thinnest track is the part that has blown.
Swapping +VE & GND means that D4 is now working a reverse protection mode - hence the blown track ...... As a side issue what sort of signal is from the TCU connection - as it goes through (I presume a high voltage diode before the lower zener?). U1 is just an oscillator with C2/R4 creating a triangle wave & R3 doing a pseudo PWM - still unsure how this varies to give the various dimmer settings, hence question abouve about TCU. Let me know if you want me to correct the schematic (give me details as ref-designators Vs values). Last edited by SURTEESS; 03-11-2012 at 02:47 PM. |
#30
The TCU signal is the Time Control Unit, sorry for the confusion. ![]() Harvey.
