Old 01-08-2011, 05:33 PM
ykobayashi's Avatar
ykobayashi ykobayashi is offline
Send a message via AIM to ykobayashi
HID Conversion
Folks,
I am planning on upgrading my headlights from stock to HID in the spring. I did a search on the forums for a "how to" but nothing that was all encompassing. I did, however, pull up a bunch of old threads from like 7 years ago talking about conversions requiring using Audi HIDs and replacing the reflectors and it costing hundreds of dollars to do so.
Recently, I did some research and found out that HID retrofit kits can now be had for about $50 or so. I specifically looked at DDM Tuning.
http://www.ddmtuning.com/Product-Cat...hting/HID-Kits
I belong to a Mazda 6 forums and fellow posters have had great success retrofitting their Mazda 6 with these kits. However, I know that SVXs are "specialized" cars and aren't as easy to retrofit as other cars. Anyone have any idea whether these DDM kits (or any other) be used on the SVX without the major surgery that was described by previous posters? Thanks for your continued help!
Yoshi
Yoshi
[B]1995 SVX L AWD - Original Owner
65k - Brilliant Red
Mods: K&N Drop In Filter, Sony aftermarket CD/MP3 Stereo and Speakers, Sumitomo HTR+ Tires
2004 Mazda 6S 5-door - Steel Grey - 5 speed manual transmission - Daily Driver
2011 Mazda CX-9 - Wife's ride
Old 01-08-2011, 05:42 PM
Geoff's Avatar
Geoff Geoff is offline
Send a message via ICQ to Geoff Send a message via Yahoo to Geoff
Re: HID Conversion
The DDM Kits work just fine. I've got a set in my car right now.
Old 01-08-2011, 05:54 PM
Re: HID Conversion
I installed OT's (svxfiles) kit in my car 3 years ago and they've worked flawlessly ever since. No surgery required. Remove old bulb, put in HID bulb, find somewhere to mount ballasts (two screws), connect wires (all direct plug in, no splicing or other crap), enjoy. The SVX already has projector headlights, so the beam pattern and cut off are perfect.
Old 01-08-2011, 06:53 PM
ykobayashi's Avatar
Re: HID Conversion
Excellent! Straight plug in or cutting and splicing required? Which wattage 35w or 55w? Did you use the Slimline or Raptor? Where did you mount the ballasts?
Thanks!
Yoshi
Yoshi
65k - Brilliant Red
Old 01-08-2011, 06:56 PM
ykobayashi's Avatar
Re: HID Conversion
Where did you get the OT's from? I am very interested since you say it a straight plug in, I am worried about having to cut and splice. Does the SVX use a universal Subaru connector? How much did they run if you don't mind me asking? Where did you mount the ballasts? Did you have to remove the front bumper to do so? Did you get the 35w or 55w? Sorry for all the questions!
Thanks much!
Yoshi
Yoshi
65k - Brilliant Red
Old 01-08-2011, 07:41 PM
92 SVX 92 SVX is offline
Re: HID Conversion
The DDM kits are plug and play, most people get the 35w kits but if you want extra bright the 55w would be ok. you can mount the ballast right behind the headlights, there is a flat area right there. no removing anything open the hood pull the old bulbs plug that connector into the ballast wiring put in the hid bulb and connect the wires.
Old 01-08-2011, 08:25 PM
Re: HID Conversion
Which DDM kit is the right one for our cars?
Old 01-08-2011, 08:26 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: HID Conversion
I picked mine up through OT as well. I placed the ballasts inside the fenders, forward of the tires. Existing threaded holes come in handy!
Old 01-08-2011, 08:33 PM
Geoff's Avatar
Re: HID Conversion
I used the 9006s, 55w, 5000k. Plenty of room to mount the ballasts, plug and play with no cutting or anything like that. Just make sure you seat the HIDs properly in the headlight housing - makes all the difference in the world. - Only $35 for the 55w Kit with a good warranty to back it up as well. New bulbs, only $12!
I went with the regular, non-slimline. Ballast on the passenger side, mounts right by the ABS pump. The other ballast, Pegdrgr of PDXTuning made an aluminum mount that screws into the side of the driver's side inner frame, so it mounts sideways...but I'm sure there are other ways to do it. Alcohol and 3M double sided tape are your friend.
Old 01-08-2011, 08:39 PM
Re: HID Conversion
OT is Old Tom, "SVXfiles" on the board. He used to sell an HID kit. Not sure if he still does??
Old 01-09-2011, 05:51 AM
Manarius's Avatar
Manarius Manarius is offline
Re: HID Conversion
I used the DDM Tuning ones. 35W 4500K. They were about $60 when I got them, I got the slim-ballasts (not by choice) and I got a lifetime warranty on the bulbs. I guess now they're about two years old, still brighter than ever.
I used to the zip ties that came with them to tie the ballasts to random things in the engine bay...like the A/C lines
-Jason
-Obi Wan Kenobi
Old 01-09-2011, 06:34 AM
Re: HID Conversion
You can make a clean installation without much work by removing the headlights and hanging the ballast below the headlight inside of the front bumper.
- Use needle nose pliers to squeeze the 2 tabs holding the top of the grill to the rad support, lift the grill out of the way.
- There is one phillips headed screw holding the corner light to the headlight, remove that and pull the corner light forward to remove.
- 4 10mm headed bolts hold the headlight into place. 2 behind the grill and 2 behind the corner light.
Old 01-09-2011, 07:49 AM
Re: HID Conversion
When svxfiles installed mine, we put them inside the front fender. Just pulled down the inner fender liners. Easy to install using existing bolts there, out of the way, protected from engine heat and moisture. I prefer the ballast brackets to be well secured to eliminate vibration or stress on the wiring.
DRIVER'S SIDE
PASSENGER'S SIDE
Since I am running HID fog lights also, the two ballasts for these are well protected and invisible inside the engine compartment.
Old 01-09-2011, 08:18 AM
LetItSnow's Avatar
Re: HID Conversion
^^ Ah, good. I don't need to take pics of mine now!
Old 01-09-2011, 03:19 PM
processengr's Avatar
Re: HID Conversion
Just a note on the DDM Tuning ballasts- on a SVX, you must reverse the plug from the headlight into the ballast, to make it work. The latch on the plug will not engage the tab on the mating connector. I have used small cable ties to secure the plug to my DDM ballasts. As mentioned, OT's Lava-luxe were a total plug and play, allowing normal connection to ballast. The DDM will come with an extion wire set, that is not needed if you are mounting the ballasts up front, like under the headlamps themselves. The DDM 2 pc slim line and the 1 pc DDM 3/4 size ballasts fit under the headlight, I don't think the full size (like the Lava-luxe) will fit there.
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
