Random honking while driving... security system?
I had this problem pop up about a month ago, and it seems to be happening more and more often now. I'll be driving along, and all of a sudden the horn will honk, randomly. Sometimes it will stop there, other times it will honk again a few moments later. Sometimes its a short honk, sometimes its a little longer. When it happened last week, I had an issue with the factory key fob working right after this happened. Since then the key fob has worked on and off intermittently. The battery in the fob is new as of this spring, so I don't think it needs to be replaced yet.
I did some searching, and couldn't come up with anything. Anyone else ever had this issue before? I'm wondering if there is something wrong with the security module? I think for now my plan of action will be to turn off the factory alarm system and see if the problem goes away, but I'm hoping someone here has a more specific answer on what could be wrong. Oh and the car is a '97 LSi if it makes any difference.
Jon 1997 SVX LSi Bordeaux Pearl 1995 SVX L AWD Polo Green - 277k miles 1986 Pontiac Fiero 3.4L Twin Dual Cam V6 Last edited by Coan; 10-04-2010 at 09:46 PM. |
Re: Random honking while driving... security system?
Any ideas at all?
Jon 1997 SVX LSi Bordeaux Pearl 1995 SVX L AWD Polo Green - 277k miles 1986 Pontiac Fiero 3.4L Twin Dual Cam V6 |
I would surmise that you are correct but not sure what is going on with it.
Keith |
Mine likes to do weird things when the battery gets low. For some reason if I have the headlights on, the fan on high, and the AC on, the battery won't charge if it's at idle, and since my battery is crap, after a while the clock starts to dim out and then the alarm starts going off.
1992 SVX LS-L #1222 Pearl White 1987 GL Turbo wagon, 5 lug conversion, D/R 5 speed (Rice killer) 1992 Dodge Ram 4x4 diesel (car hauler) 1968 Dodge Polara convertible (Camaro killer) 1990 Toyota Corolla FWD auto (330,000 mile grocery getter) 1986 VW Jetta |
Postcount 1UP! |
I'm sure this must be frustrating. I don't have a helpful suggestion at this time but I can point you to this to make you feel better:
http://www.youtube.com/watch?v=m2vGGm3U6gg
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
I forgot to turn off the security button when I drove it today, but it didn't do it so next time it does then I will turn the switch off. And as for the battery/idle thing, it doesn't just do it at idle, it really is totally random. Happens when at idle, when cruising at 50 mph, when cruising at 70 mph, even once while accelerating. I can't seem to find any pattern to it or anything, and it's not caused by vibration/bumps in the road either. The only thing I do know is that every time it has happened, the car was fully warmed up and driven for at least 10 minutes. When I get a chance, I'll get under the hood and start inspecting all of the horn wiring too.
sounds like it might be security related the security systems age and alot of them have died based upon what i have heard. this sounds like that is the case in this situation. Welcome to the club!!!
William |
Zombie thread resurrection!
Years later, I finally solved this issue! I actually resorted to unplugging my horn during the summer months because this only happened during warm weather. I recently noticed my parking lights randomly coming on, and one day after my commute home they were stuck on. I unplugged the security module and they went out. Ended up replacing the module and reconnected the horn and all is good now. Turns out it was the security module, just like I had apparently suspected many years ago. Shoulda done that years ago! Just wanted to conclude this thread in case anybody has a similar issue and ends up coming across this thread.
Great to hear you fixed it. Even better you came back to post your solution.
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
I have to admit that it took me a while to find this thread, but I knew I had started one...just didn't realize it was that long ago.
this happened to mine and ended up being the alternator. occasionally would have too much ac ripple and screw up the alarm. three bad new alternators later then was not an issue. i had to drive my lowered volvo 740 to the parts store in a foot of snow to return an alternator i had just bought the day before. if you keep having problems i would check your alternator.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
just realized i posted to original post that was already solved without reading the rest of the thread. see what happens when you are gone for a year?
Replacement was from a local junkyard car (the one and only time my local yard had an SVX, many years ago). I wasn't expecting a junkyard module to be good but I guess I got lucky!
